ac compressor problems #1834828
05/26/15 09:01 PM
05/26/15 09:01 PM
S.florida
Jupiter331 Offline OP
S.florida
I have a 70 440 with factory ac. Rebuilt factory compressor seems to be seizing up. Belt is slipping and compressor is turning slowly when engaged. Has oil. I feel the problem occurred trying to charge the system by jumping the compressor. We had a problem charging and it probably ran too long without gas. It hasn't completely seized yet. Is there any way to fix the compressor at this point without a total rebuild? Any ideas appreciated
Re: ac compressor problems [Re: Jupiter331] #1834830
05/26/15 09:06 PM
05/26/15 09:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oil for the factory compressor is in a sump, kinda like a V twin Harley. Doesn't really need gas to oil the compressor.
What are your pressures? Might be too much gas. You didn't dump liquid freon in to the low pressure side did you?
Don't be the exception.
Re: ac compressor problems [Re: Jupiter331] #1834866
05/26/15 10:00 PM
05/26/15 10:00 PM
S.florida
S.florida
It's converted to 134a. It started doing this before we started to charge it
Re: ac compressor problems [Re: Jupiter331] #1834989
05/27/15 01:01 AM
05/27/15 01:01 AM
Washington/Las Vegas
1971 Gran Coupe Offline
This in one of the things that is difficult to diagnose over a forum, but I have seen overcharged systems act the way you are describing. Were gauges used with the recharging. I usually will not jump the compressor, but will start a light recharge and let the system equalize until the compressor starts to engage, then continue with the recharge.
I am sure there will be some pros along shortly to add to your items to check.
