inverted rear shock? #1834393
05/26/15 10:35 AM
05/26/15 10:35 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My axle tube is hitting my shock tube on launch so I would like to get an inverted shock dbl adj for stock mounts,length.I am using caltracs just touching both springs.
Thanks for the help.
Re: inverted rear shock? [Re: Clanton] #1834415
05/26/15 11:11 AM
05/26/15 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you tend to drag race why dont you relocate the
shocks.. stand them upright and move the bottom of
the shock back another 1/2".. this would give you
the best of both worlds
wave
Re: inverted rear shock? [Re: MR_P_BODY] #1834423
05/26/15 11:22 AM
05/26/15 11:22 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
wave
The simple answer is it is easier to replace the shock.I like to think the stock angle of the shock will help sway,prevent tire rub on the fender...
JMO.I would like to go this way.
Re: inverted rear shock? [Re: Clanton] #1834433
05/26/15 11:37 AM
05/26/15 11:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
If your concerned with other issues, then kick them
back a 1/2".. same angles... this should clear and
be the cheapest way out of the problem... will other
shocks help.. maybe be.. but I'm looking at what will
fix your issue
EDIT
I'm talking kicking the bottom of the shock back
wave
Re: inverted rear shock? [Re: MR_P_BODY] #1834441
05/26/15 11:51 AM
05/26/15 11:51 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
wave
fix your issue
EDIT
wave
I am not so sure moving it back is a fix.The axle hit the rancho's and the tube is 2 3/4" and a QA-1 is 2" and who knows where it would stop[unsure]The inverted shock would give it the most clearance and may be equal to moving the shock back.The ranch tubes got dented 1/4" and I did not hit the tires hard full hook.
Re: inverted rear shock? [Re: Clanton] #1834451
05/26/15 12:04 PM
05/26/15 12:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
cool
Re: inverted rear shock? [Re: jcc] #1834460
05/26/15 12:16 PM
05/26/15 12:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By jcc
Would simply inverting your current shock solve the issue? I don't see a problem other then maybe on an adjustable with aeration affecting the control valving. Corner turners do it for less unsprung weight, but it raises COG a minuscule and takes the shock out of any cooling airflow, not much of a concern when used at 1/4 mile at a time. I would at least try it or contact manufacturer. Shock can't tell orientation on compression or rebound.
Some shocks do know orientation... but that was
usually the older style shocks.. gas pressure
shocks dont normally have the issue.... so try
flipping them over... it sounds like it'll be a
yes or no answer
wave
Re: inverted rear shock? [Re: Clanton] #1834465
05/26/15 12:23 PM
05/26/15 12:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am sure my rancho is toast with a dented tube[both of them]and the rancho directions do state up/down.The QA-1 tech on the phone just said the TD901 can be inverted,I am just not sure on the valving being strong enough ootb.
Re: inverted rear shock? [Re: Clanton] #1834483
05/26/15 12:42 PM
05/26/15 12:42 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why not FIX the problem...........If the housing is rolling back hard enough at launch to bend the shocks......FIX it.
Monte
Re: inverted rear shock? [Re: Clanton] #1834490
05/26/15 12:52 PM
05/26/15 12:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Had the same issues w/my Ranchos also and was told NOT to run em upside down so I moved the shocks more upright from stock location and problem solved although it sounds like the QA-1's may solve that for ya. Fun stuff always.......
Re: inverted rear shock? [Re: Clanton] #1834516
05/26/15 01:38 PM
05/26/15 01:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the info on the Rancho.
Re: inverted rear shock? [Re: Clanton] #1835447
05/27/15 06:22 PM
05/27/15 06:22 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have plenty of room now I think.
Re: inverted rear shock? [Re: Clanton] #1835590
05/27/15 10:27 PM
05/27/15 10:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I think I see a set of worn out/bent shocks in your future...you put the smallest Dia at the greatest arc load...as Monte said...Fix the problem.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: inverted rear shock? [Re: Clanton] #1835612
05/27/15 10:50 PM
05/27/15 10:50 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Yeah Mike, gotta agree with Monte too.. If you are rolling the axle enough to damage shocks you may want to look at why. Inverting the shock is only a band aid.
Randy
Re: inverted rear shock? [Re: Clanton] #1835661
05/27/15 11:53 PM
05/27/15 11:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Why is I have enough TQ to twist the spring,I think a Mono spring would do the same thing.Now I have not put more load on the caltrac bars so maybe it needs some of that also.Fix it?othersw have moved the shock to the front.
Re: inverted rear shock? [Re: Clanton] #1835809
05/28/15 08:43 AM
05/28/15 08:43 AM
ohio
all spooled up Offline
ohio
you know what larry morgan whould say..
Re: inverted rear shock? [Re: Clanton] #1835860
05/28/15 10:48 AM
05/28/15 10:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am looking at options for the upper shock mount in front of the axle.Is there a shock tab to weld to the frame without the full cross member?What shock kit if full cross tube mount?34"
Re: inverted rear shock? [Re: Clanton] #1836036
05/28/15 03:26 PM
05/28/15 03:26 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There is no need to move the shocks, just fix the housing roll. The Cal-Tracks and other bars are designed to do that, so if it is rolling hard enough to damage the shocks, something is not set up or adjusted right. Plenty of people run the shocks in stock location and don't bend them, you shouldn't either. Sure, you can move the shock, but that doesn't "fix" the problem
Monte
Re: inverted rear shock? [Re: Clanton] #1836065
05/28/15 04:19 PM
05/28/15 04:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks I am unsure on how much pre load I can put in to it to stop it.Or how much I should.I just put them on the car and was my 1st time out with it.
Re: inverted rear shock? [Re: Clanton] #1836074
05/28/15 04:49 PM
05/28/15 04:49 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
This is off the subject, but I couldn't help but notice that you're running hard brake line directly to your rear calipers. You should have a short length of flex hose that connects the calipers to a fixed bracket supporting the hard line. This will allow removal of the calipers, for pad replacement.
Gone to the dark side with an LS3 powered '57 Chevy 210
