340 main SB stroker main bearings #1834349
05/26/15 03:39 AM
05/26/15 03:39 AM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
What's everyone running? I've been squirreling away parts for my 4.125" BPE crank 427" motor (R1A based build) and came across a set of clevite MS-540H bearings new in the box for half of their new cost. Obviously final oil clearance dictates if they will work for my situation, but has anyone else has any dealings with them? They appear to be a 1/2 groove bearing. My previous 408 used speed pro 3/4 groove bearings, which worked well in my 360 main block. What's everyone run in their 340 main engines? Thanks
http://m.summitracing.com/parts/cle-ms540h
Re: 340 main SB stroker main bearings [Re: 340_Dart] #1834351
05/26/15 04:05 AM
05/26/15 04:05 AM
Australia Qld
V
VG423 Offline
VG423  Offline
V
Australia Qld
My old 340 mains 4.00 stroke engine ran Hughes Hug 4002 1/2 groove tri metal bearings.
My new BPE 4.125 (360 mains) was supplied with clevite MS-1266 P full groove bearings.
Re: 340 main SB stroker main bearings [Re: 340_Dart] #1834391
05/26/15 10:32 AM
05/26/15 10:32 AM
Out West
408strokerdart Offline
Out West
I think that is the bearing I use in mine. No problems what so ever.
Re: 340 main SB stroker main bearings [Re: 340_Dart] #1834394
05/26/15 10:36 AM
05/26/15 10:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used full groove Clevites in my 408, the R1 build will 1/2 groove Kings in.
Re: 340 main SB stroker main bearings [Re: 340_Dart] #1834407
05/26/15 11:01 AM
05/26/15 11:01 AM
BPE Offline
BPE  Offline
MS 540H will work for yours Andy.
Rod
Re: 340 main SB stroker main bearings [Re: BPE] #1834499
05/26/15 01:08 PM
05/26/15 01:08 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Thanks for the replies. I'll get them for the build.
