How do I bypass clutch safety switch on '73 4 speed RR? #1834259
05/26/15 12:05 AM
05/26/15 12:05 AM
Salem, OH (Quaker City Raceway...
GuruRanger Offline OP
I have a rusty, crusty old 1973 4 speed Road Runner. It's a parts car that hasn't died yet. I accidentally mashed the clutch starter safety switch in it. If I can't get the old one working, how can I bypass it? I will be the last person to ever own and drive this car as a complete car (the parts will eventually go into my '74 project), so the safety part is not a huge factor to me.
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: GuruRanger] #1834261
05/26/15 12:10 AM
05/26/15 12:10 AM
Maryland
gofastboater Offline
Maryland
If the switch has 2 wires just put them together. If only one wire just ground it.
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: GuruRanger] #1834265
05/26/15 12:12 AM
05/26/15 12:12 AM
Maryland
Maryland
Are you selling any parts off of it??
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: gofastboater] #1834272
05/26/15 12:21 AM
05/26/15 12:21 AM
Wow! You guys are like vultures LOL! Just kidding, I'd do the same thing. No, I'm not selling anything off of it. It's been sitting behind my garage for several years and I just got it running and back on the road today. I have to start it by arcing the starter relay until I get that clutch safety switch fixed or bypassed. Thanks for the quick answer!
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: GuruRanger] #1834278
05/26/15 12:39 AM
05/26/15 12:39 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take the wire from the starter relay to the pedal switch and ground it leaving it attached to the relay terminal. I believe the clutch pedal switch is just a ground.
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: stumpy] #1834303
05/26/15 01:20 AM
05/26/15 01:20 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's correct Stumpy, you can do it right at the relay near the battery, takes about 5 seconds.
Sheldon
Sheldon
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: GuruRanger] #1834936
05/26/15 11:28 PM
05/26/15 11:28 PM
It worked great guys! Thanks!
Re: How do I bypass clutch safety switch on '73 4 speed RR? [Re: GuruRanger] #1834982
05/27/15 12:52 AM
05/27/15 12:52 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any time. Glad it worked. up
