Annular Boosters for Edelbrock carbs? #1833865
05/25/15 02:05 PM
05/25/15 02:05 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
Does anyone make/sell annular boosters for edelbrock/carter style carbs? Thanks
Re: Annular Boosters for Edelbrock carbs? [Re: PJ68RT] #1833930
05/25/15 03:30 PM
05/25/15 03:30 PM
Probally not, have you looked at the rear fuel feed devises on the AVS style carbs, same as the Thermoquads scope Are you aware that most of the 4150 Holley carbs with annular booster, go fatter the higher you rev the motor work down twocentsAnother thing to keep in mind is that the skirts on the annular boosters limit the airflow to less than with conventional boosters in the same carb work scope
