Re: VIN on Hemi's....??
[Re: ScottSmith_Harms]
#1833466
05/24/15 09:44 PM
05/24/15 09:44 PM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
Always the VIN. Not looking at a red 68 Hemi Charger are you? ME...no......just looking to I.D. a late 66 model block..... Thanks for the info.... I was thinking it went along with the B & RB's but was not 100% sure...
[Re: MI_Custumz]
#1833780
05/25/15 12:04 PM
05/25/15 12:04 PM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
Was 1968 the VIN or VON? I know a friend had a numbers matching 68 Coronet with a 383 and it was the VON and that matched the fender tag. Had to have the broadcast sheet to match the VON to the VIN. You may be thinking about the body stampings that were the SO number until 1969.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: E-Ticket]
#1833804
05/25/15 12:44 PM
05/25/15 12:44 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Which is a common reason for confusion, in 1968 the VIN sequence was on the engine and transmission but the Vehicle Order Number was stamped into the body. The later cars had the VIN Sequence in all locations.
