anti rattle clips #1833083
05/24/15 02:06 AM
05/24/15 02:06 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi 1970 gtx anti rattle clips for front brake were can i get them.i need one for each bolt or positioner
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: anti rattle clips [Re: GTXKARL] #1833099
05/24/15 02:57 AM
05/24/15 02:57 AM
WA
tman Offline
tman  Offline
WA
Are you talking about the wire clip like in this hardware kit?
http://www.autopartswarehouse.com/sku/Pl...aa-e53cc74c5c1b
If so, Rockauto has the same Centric kit for $8.23. Not sure if you can just get the 2 springs. Or your regular auto parts store will probably have this kit.
Re: anti rattle clips [Re: GTXKARL] #1833102
05/24/15 03:30 AM
05/24/15 03:30 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bill Rollik is one place. There may be others?
http://www.billrolikenterprises.com/products.asp?cat=14
http://www.billrolikenterprises.com/proddetail.asp?prod=2944722%2D3%2DP
I though he had the small hex pins, but I can't find them there?
Re: anti rattle clips [Re: GTXKARL] #1833142
05/24/15 10:40 AM
05/24/15 10:40 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you're talking about the ones in the picture that autoxcuda has posted, you don't need them, don't worry about it, it will work fine without them, and run cooler also.
