VIN on Hemi's....?? #1833043
05/24/15 12:21 AM
05/24/15 12:21 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
What month & year did they start stamping VIN's on the hemi blocks...?? Were they done in sequence with the B & RB blocks also...??
Thanks....!!
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833078
05/24/15 01:56 AM
05/24/15 01:56 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It started in 1968 for Hemi's, ALL of 1968.
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833321
05/24/15 04:33 PM
05/24/15 04:33 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Was 1968 the VIN or VON? I know a friend had a numbers matching 68 Coronet with a 383 and it was the VON and that matched the fender tag. Had to have the broadcast sheet to match the VON to the VIN.
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833324
05/24/15 04:37 PM
05/24/15 04:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Always the VIN. Not looking at a red 68 Hemi Charger are you?
Re: VIN on Hemi's....?? [Re: ScottSmith_Harms] #1833466
05/24/15 09:44 PM
05/24/15 09:44 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
ME...no......just looking to I.D. a late 66 model block..... Thanks for the info.... I was thinking it went along with the B & RB's but was not 100% sure...
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833476
05/24/15 10:04 PM
05/24/15 10:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The VIN sequence # would be stamped on the top back of the block adjacent to the oil sender hole, right into raw cast iron, sometimes hard to read.
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833743
05/25/15 11:09 AM
05/25/15 11:09 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What is stamped on the upper I.D. Pad? Post a pic if you can
Re: VIN on Hemi's....?? [Re: MI_Custumz] #1833780
05/25/15 12:04 PM
05/25/15 12:04 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
You may be thinking about the body stampings that were the SO number until 1969.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833804
05/25/15 12:44 PM
05/25/15 12:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Which is a common reason for confusion, in 1968 the VIN sequence was on the engine and transmission but the Vehicle Order Number was stamped into the body. The later cars had the VIN Sequence in all locations.
Re: VIN on Hemi's....?? [Re: E-Ticket] #1833855
05/25/15 01:56 PM
05/25/15 01:56 PM
MI_Custumz Offline
MI_Custumz  Offline
Ah, didn't know that. Knew it was VIN's all around in 1969.
