need some help on brakes #183302
01/04/09 01:18 AM
01/04/09 01:18 AM
fresno
hyefatman Offline OP
fresno
i am in the process of restoring my 1968 charges
i added disc front brakes with a power brake booster ... i bleed the brakes but noticed the brake pedal was no coming back up i thought this was because the motor was not running but 2day after i broke in the cam ...it did the same thing as before... does the car have a spring that pulls the brake pedal back toward the driver ? what else could it b ?
Re: need some help on brakes [Re: hyefatman] #183303
01/04/09 01:49 AM
01/04/09 01:49 AM
booster
