mopars flat black paint code?? #1833010
05/23/15 11:02 PM
05/23/15 11:02 PM
Finally a HUSKER again
Moparnut426 Offline OP
The Cuda is coming along really great, whats the paint code for the flat black?
Re: mopars flat black paint code?? [Re: Moparnut426] #1833064
05/24/15 01:04 AM
05/24/15 01:04 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Original stuff was lacquer, but not all the ingredients used to create it exist anymore. The DCC urethane is the modern version, but has no texture to it. You can buy ppg texture additive (ppg# 1999) to give it texture if you want.
https://board.moparts.org/ubbthreads/ubbt...ype/thread.html
Planet Color has a textured black under their rugged tones paint line that a guy here used on his barracuda hood that looks nice.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/5666719/site_id/1
Re: mopars flat black paint code?? [Re: Neil] #1834683
05/26/15 05:39 PM
05/26/15 05:39 PM
South Dakota
hotairballoonpilot Offline
South Dakota
dads cuda I did in the concept DDC. I just played with gun and adjustment until I got the texture I felt looked good. I cut air and volume up and down until it went on really rough. If you spray it like a regular paint it will lay out like a normal paint.
Contact Me about AMD Prices
Re: mopars flat black paint code?? [Re: hotairballoonpilot] #1834684
05/26/15 05:41 PM
05/26/15 05:41 PM
South Dakota
South Dakota
btw I checked with ABS here in SF. The PPG texture additive is discontinued so unless you find a jobber with it on the shelf you are SOL on that.
