Any members mill choke horns.......
#183269
01/04/09 12:36 AM
01/04/09 12:36 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Any members mill choke horns off of carbs? Ive got one I need milled off. Thanks
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Any members mill choke horns.......
[Re: RoadSkinner]
#183272
01/04/09 02:01 PM
01/04/09 02:01 PM
Posts: 15,489 the boonies
aarcuda
the boonies
Sure do , they can be milled flush with top or contoured with the opening around the boosters ....can also put in removeable air bleeds ......just about anythig u need done...... .PM me
let me ask, would smaller idle air bleeds be the alternative to drilling holes in the throttle plates?
[Re: 440W8 Duster]
#183273
01/04/09 03:09 PM
01/04/09 03:09 PM
Von
NE Oklahoma
Might be better to just invest in a Proform Main body.bye the time you ship it get it milled and shipped back you'll be about the same $.The Proform Maind body should flow a bit more CFM.
Good point, cept where do you find a PF main body for a 850 for close to 50 bucks?
[Re: 383man]
#183275
01/04/09 03:54 PM
01/04/09 03:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Von, a hack saw blade costs a dollar and will take you ten minutes to cut it off. it will take longer to package and send
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#183276
01/04/09 07:27 PM
01/04/09 07:27 PM
EXACTLY..........don't over rocketeer it.......
#183277
01/04/09 09:22 PM
01/04/09 09:22 PM
Von
NE Oklahoma
Except Im picky as crap and no way could I make it look decent.
[Re: RoadSkinner]
#183280
01/04/09 10:12 PM
01/04/09 10:12 PM
Von
NE Oklahoma
U can buy a procomp contoured main body for about $60 but
Where can you get the 850 body for 60 bucks?
[Re: Sport440]
#183281
01/04/09 10:12 PM
01/04/09 10:12 PM
Von
NE Oklahoma
Von, if this carb is for your current combo. If you havent allready I would just remove the flap and the shaft of your 850 and call it good.
That way you can later return it to its orginal state later and sell it if you really want to upgrade. mike
Mike,
Its not my current carb. Im building a carb for E85.
[Re: RoadSkinner]
#183284
01/04/09 11:54 PM
01/04/09 11:54 PM
Von
NE Oklahoma
Sorry , I just checked the web site and they just went up , now they are $69 .....they were $59
Thanks, that is interesting. I had noticed the proform bodys, but hadnt seen the procomps.
Are the procomp bodys decent enough?
Do the procomp 850 bodys have the same venturi/bore diameter as a 850 Holley?
[Re: Von]
#183285
01/05/09 12:26 PM
01/05/09 12:26 PM
I took the airhorn off a 750 3310 with a die grinder and a cutoff wheel a few years back. I used a dremel tool to clean it up and make it look nice. Make sure you clean it up thoroughly after "makin' chips".
[Re: StrokerPost]
#183287
01/05/09 06:53 PM
01/05/09 06:53 PM
Posts: 3,095 Idaho
Runner
Idaho
I'd forget the milling and pick me up one of these. http://www.knfilters.com/Racing/stubstacks.htm seen more than one guy just bolt one one with no ther mods and pick up over a 1/2 tenth. I think they were around $30 or so.
my experience with a stubstack wasn't good at all. they might work with out an air cleaner or a really tall one but for me the car wouldnt pull over 5200 rpm with a 3 inch drop base k&n filter. it seems they are really hit and miss.
[Re: Runner]
#183288
01/05/09 08:03 PM
01/05/09 08:03 PM
Triple Threat
Renton Washington
I tried a stub stack once, didn't make any difference.
Still have it laying around somewhere, but I have a HP main body now so there isn't any point in using it.
