Any members mill choke horns....... #183269
01/04/09 12:36 AM
01/04/09 12:36 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Any members mill choke horns off of carbs? Ive got one I need milled off.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Any members mill choke horns....... [Re: Von] #183270
01/04/09 03:32 AM
01/04/09 03:32 AM
Upper Sandusky, Ohio
RoadSkinner Offline
RoadSkinner  Offline
Sure do , they can be milled flush with top or contoured with the opening around the boosters ....can also put in removeable air bleeds ......just about anythig u need done...... .PM me
Re: Any members mill choke horns....... [Re: RoadSkinner] #183271
01/04/09 01:57 PM
01/04/09 01:57 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Might be better to just invest in a Proform Main body.bye the time you ship it get it milled and shipped back you'll be about the same $.The Proform Maind body should flow a bit more CFM.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Any members mill choke horns....... [Re: RoadSkinner] #183272
01/04/09 02:01 PM
01/04/09 02:01 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
let me ask, would smaller idle air bleeds be the alternative to drilling holes in the throttle plates?
Re: Any members mill choke horns....... [Re: 440W8 Duster] #183273
01/04/09 03:09 PM
01/04/09 03:09 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Good point, cept where do you find a PF main body for a 850 for close to 50 bucks?
Re: Any members mill choke horns....... [Re: Von] #183274
01/04/09 03:39 PM
01/04/09 03:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Von I dont know who milled the one on the 750 thats on my sons 400 as I got this carb in a trade with my brother when I traded some 4.88 gears I had for this 750. But it runs good on his Dart as the 800 DP and 830 anular carb we tried did not run any better and he went back to the 750 as it just works good on his 400. Ron
Re: Any members mill choke horns....... [Re: 383man] #183275
01/04/09 03:54 PM
01/04/09 03:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Von, a hack saw blade costs a dollar and will take you ten minutes to cut it off. it will take longer to package and send
Re: Any members mill choke horns....... [Re: sixpackgut] #183276
01/04/09 07:27 PM
01/04/09 07:27 PM
EXACTLY..........don't over rocketeer it.......
Re: Any members mill choke horns....... #183277
01/04/09 09:22 PM
01/04/09 09:22 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Except Im picky as crap and no way could I make it look decent.
Re: Any members mill choke horns....... [Re: Von] #183278
01/04/09 09:46 PM
01/04/09 09:46 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Von, if this carb is for your current combo. If you havent allready I would just remove the flap and the shaft of your 850 and call it good.
That way you can later return it to its orginal state later and sell it if you really want to upgrade. mike
Re: Any members mill choke horns....... [Re: Sport440] #183279
01/04/09 10:03 PM
01/04/09 10:03 PM
RoadSkinner Offline
RoadSkinner  Offline
Ive never had to drill the butter fly s , When u drill them out u are just covering up a problem elsewhere .....Going smaller on the air bleeds will make the mixture a little richer ....U can buy a procomp contoured main body for about $60 but then it has to b redrill because the passages are in the wrong places .....
Re: Any members mill choke horns....... [Re: RoadSkinner] #183280
01/04/09 10:12 PM
01/04/09 10:12 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Where can you get the 850 body for 60 bucks?
Re: Any members mill choke horns....... [Re: Sport440] #183281
01/04/09 10:12 PM
01/04/09 10:12 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Mike,
Its not my current carb. Im building a carb for E85.
Re: Any members mill choke horns....... [Re: Von] #183282
01/04/09 10:27 PM
01/04/09 10:27 PM
RoadSkinner Offline
RoadSkinner  Offline
Go to PROCOMP ELECTRONICS .COM
Re: Any members mill choke horns....... [Re: RoadSkinner] #183283
01/04/09 10:31 PM
01/04/09 10:31 PM
RoadSkinner Offline
RoadSkinner  Offline
Sorry , I just checked the web site and they just went up , now they are $69 .....they were $59
Re: Any members mill choke horns....... [Re: RoadSkinner] #183284
01/04/09 11:54 PM
01/04/09 11:54 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Thanks, that is interesting. I had noticed the proform bodys, but hadnt seen the procomps.
Are the procomp bodys decent enough?
Do the procomp 850 bodys have the same venturi/bore diameter as a 850 Holley?
Re: Any members mill choke horns....... [Re: Von] #183285
01/05/09 12:26 PM
01/05/09 12:26 PM
I took the airhorn off a 750 3310 with a die grinder and a cutoff wheel a few years back. I used a dremel tool to clean it up and make it look nice. Make sure you clean it up thoroughly after "makin' chips".
Re: Any members mill choke horns....... [Re: Von] #183286
01/05/09 01:22 PM
01/05/09 01:22 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
I'd forget the milling and pick me up one of these. http://www.knfilters.com/Racing/stubstacks.htm seen more than one guy just bolt one one with no ther mods and pick up over a 1/2 tenth. I think they were around $30 or so.
Re: Any members mill choke horns....... [Re: StrokerPost] #183287
01/05/09 06:53 PM
01/05/09 06:53 PM
Idaho
Runner Offline
Runner  Offline
Idaho
my experience with a stubstack wasn't good at all. they might work with out an air cleaner or a really tall one but for me the car wouldnt pull over 5200 rpm with a 3 inch drop base k&n filter. it seems they are really hit and miss.
Re: Any members mill choke horns....... [Re: Runner] #183288
01/05/09 08:03 PM
01/05/09 08:03 PM
Renton Washington
Triple Threat Offline
Renton Washington
I tried a stub stack once, didn't make any difference.
Still have it laying around somewhere, but I have a HP main body now so there isn't any point in using it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Any members mill choke horns....... [Re: Triple Threat] #183289
01/05/09 08:07 PM
01/05/09 08:07 PM
Central NC
gch Offline
gch  Offline
Central NC
My experience with a stub stack is if you don't run a tall air filter it will have a hesitation.I tried it with a 3" air filter and it would hesitate every time.Put a 5" air filter on there and it went away.Can't say if it helped ET or not.Never tested it at the track.
Re: Any members mill choke horns....... [Re: gch] #183290
01/05/09 08:58 PM
01/05/09 08:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I purchased the K&N stack for a Holley carb with the air horn milled, part #85-0400. It seemed like a good idea. However, the fit was very poor, so I made my own. This is on a 4781.
