Re: cranr gold rocker limit ?
[Re: calrobb2000]
#1833036
05/24/15 12:13 AM
05/24/15 12:13 AM
Posts: 561 USA
B3RE
USA
hi anyone know the spring limit of the crane gold roller tip aluminum rocker arms ?
thank you ! On a related note, I would recommend having full time oiling to the rocker shafts once the spring pressures get over 350 pounds to reduce the chance of galling.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#1833046
05/24/15 12:23 AM
05/24/15 12:23 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
thank you ! On a related note, I would recommend having full time oiling to the rocker shafts once the spring pressures get over 350 pounds to reduce the chance of galling. I have the number four cam journal gooved on all my roller cams that are not grooved already to oil the rocker full time and then use a restrictor sized as needed to prevent flooding the top end Full time oiling to the rocker arms helps cool the valve springs besides preventing galling on extruded aluminum rocker arms
[Re: Cab_Burge]
#1833444
05/24/15 09:24 PM
05/24/15 09:24 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
373# open, standard cam bearings, 40 psi at 4900 rpm. Take your pick of the cause, this was the result.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
