SB rocker arm shaft - end plugs, source?
#1832389
05/22/15 07:19 PM
05/22/15 07:19 PM
Posts: 1,758 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I am hoping to toss my Crane 1.6 ratio rocker arms on the motor this weekend but am missing the tiniest little part...LOL... Where can I find the rocker arm shaft end-plugs? I decided to set up a separate rocker arm & shaft assembly for the Crane rockers so this is basically a "quick" swap. That way I won't mix up the rocker arm spacing vs valve stem and so forth between the 2 different rocker sets. The shafts are from the MP W2 P4876343 set. They are on-center and use a press-in plugs. I pulled the plugs as the shafts had some surface rust and I cleaned them up. Now I'm trying to find a new set of plugs and my God...NO ONE has them!!! The plugs I pulled out are .530 diameter. The shaft ends are tapered and go from about .535 to .500 where the taper ends. I'm thinking the closest I will get to this is something like a 17/32 plug, but all the local stores I checked do not have this. I see MP has P5249633 - Mopar Performance Hemi Rocker Arms & Components, but no idea what size these are. The closest other alternative is a Doorman expansion plug, their catalog claims to be a 0.536" open end diameter. Anything else I could try???
Re: SB rocker arm shaft - end plugs, source?
[Re: Diplomat360]
#1832411
05/22/15 08:00 PM
05/22/15 08:00 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Do those shafts have enough meat to tap and install pipe plugs?
RIP Monte Smith
[Re: CompWedgeEngines]
#1832426
05/22/15 08:30 PM
05/22/15 08:30 PM
Diplomat360
Windsor, ON, Canada
Do those shafts have enough meat to tap and install pipe plugs? Yeah, I think so...the fully machined section of the shaft, so the actual open center I.D. is 0.500", whereas the tapered ends flare out to about 0.535"...there appears plenty of metal left, so I think that might work. That idea crossed my mind but I have no idea how difficult it would be to do this? Do I just grab the closest tap and attempt to make some threads in there? (assuming I can find the matching plug of course)
[Re: Diplomat360]
#1832467
05/22/15 09:25 PM
05/22/15 09:25 PM
Posts: 561 USA
B3RE
USA
You will have to cut through the surface hardening with something carbide. A pipe tap won't cut it. You can make your own plugs if you have access to a lathe and some mild steel rod. I've had to do that on some of the thick wall shafts.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: Diplomat360]
#1832877
05/23/15 05:10 PM
05/23/15 05:10 PM
Posts: 62 montreal, quebec,canada
7e5dartsport
diplomat360- youre welcome. i even found the real plugs. look at e bay again. ad number is eBay item number:
171766137292. also eBay item number:
361214960504, or do a search on ebay under ``318 rocker shaft``.
fully legal sounds the same as full illegal...
[Re: Diplomat360]
#1832913
05/23/15 06:55 PM
05/23/15 06:55 PM
Posts: 2,073 CA
crackedback
CA
[Re: Diplomat360]
#1833024
05/23/15 11:54 PM
05/23/15 11:54 PM
Posts: 561 USA
B3RE
USA
7e5dartsport: Thank you...that is precisely what I needed.
B3RE: Hmm...I only wish I had access to such machinery (lathe)...no seriously, I would love to learn and try this...but for this guy, it's very much a "poor man's garage" approach... I wasn't aware of your machining capabilities, but I figured it was worth suggesting. When I had to make them, it was out of sheer necessity, because this company, which will remain anonymous, couldn't seem to hold a tolerance on the plug bores, and nothing in the expansion plug catalog would fit. Didn't know if you might be in the same predicament.
Mike Beachel
[Re: B3RE]
#1833150
05/24/15 11:01 AM
05/24/15 11:01 AM
Diplomat360
Windsor, ON, Canada
I wasn't aware of your machining capabilities, but I figured it was worth suggesting... Oh, no problem, I completely took it as that, a great suggestion which given the means availability would probably be the best way to resolve this issue. For now I'm going to cross my fingers and give the Dorman plugs a try. Co-incidentally I found a Mopar specific "Rocker Arm Shaft Plug" in their catalog, but that is a #555-067, which is listed as 39/64" diameter...and that is simply too big for my MP shafts. I've attached the PDF catalogs, both the Make specific stuff and the MISC section.
[Re: Diplomat360]
#1834557
05/26/15 02:37 PM
05/26/15 02:37 PM
dogdays
Bought mine over the counter at NAPA. I walked into the store, told the parts guy what I needed, rocker shaft plugs for a 318, he looked them up, went in the back and came out with four.
Product ImageLogo Image
Expansion Plug, .625"; 15.875 mm Part Number: SEP 3813052
Product Line: Sealed Power Engine Parts
IMPORTANT INFO: Rocker Arm Shaft End,5/8",Steel
Add to Compare
$0.69 /ea
Call Store for Availability
Quantity: Reserve & Pick Up
R.
