Page 1 of 4 1 2 3 4 >
#1832092 - 05/22/15 10:28 AM 69 Belvedere 4 door to 2 door conversion
Silver70 Online   tonguue
Loc: Rust Belt, SW PA
I bought this car over a month ago on ehay. Looked too cool for the price to pass up and wasn't much info in the auction. Someone talked me into buying it, so took a chance without more info since it was in the south west. I figured worst case good parts car. Well it arrived, floor was shot, lots of wiring and stuff I didn't like plus a slant 6/3 speed with a floor shifter I couldn't shift well laugh2 I didn't want to put $ into a 4 door so decided instead of cutting up for parts, I'd make it into something I'd like.
So here it is, the not as easy a the older b-body 4 to 2 door conversion.
How it looked when it arrived:
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#1832093 - 05/22/15 10:31 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
Time to start cutting!
#1832094 - 05/22/15 10:33 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
Roof had to go
#1832095 - 05/22/15 10:35 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
More metal removal
#1832100 - 05/22/15 10:37 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
And the donor and roof section
#1832103 - 05/22/15 10:39 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
And with a little help setting in place, the roof section went on fairly easy
#1832106 - 05/22/15 10:41 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
All welded at pinch weld and so on... and new quarter starting to be installed
#1832108 - 05/22/15 10:42 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
Quarters fit so good, goodmark, that I got them and the deck filler done in an afternoon... still some welding to finish, but more than happy with how well it went
#1832115 - 05/22/15 10:46 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
That's as far as I got on it in the last week or so now. My garage is too full so have to work on it outside. Weather didn't agree yesterday.
I can say it wasn't the easiest conversion, but definitely not the most difficult either. I still have to change the roof skin. I wanted to use a structure that was all one piece to keep things square.
I was told I was crazy for taking doing this... but I don't think it was any worse than doing full frame rails and such.
#1832124 - 05/22/15 10:59 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
basketcase Offline
Loc: east side of Ohio
will be watching this one. popcorn crazy? maybe so, but isn't anyone messing with old cars?
you got some mad skills there! sawzall weld primer thumbs
1969 Plymouth road runner post 383 4 speed F8
1981 Dodge D150 360 auto
#1832132 - 05/22/15 11:10 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Very nice! I'd have done the same thing...if I had your welding and fabrication skills, lol.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
#1832150 - 05/22/15 11:41 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
I already have two 2 doors, but both I couldn't justify cutting/modifying to do what I wanted with. The satellite is already redone and way too original... my roadrunner is 95% plus original sheetmetal. So figured with this I'd have no problem putting in a rollbar, minitub it and so on. It will be a street car, but more of a track car.
It really was easy in my mind, just a ton of cutting and drilling. I did the apillars to the factory spots. The rear panels to rocker and wheel houses, they were in between, so I overlapped and welded in place... reason for the seam sealer. That and I wasn't going for a perfect factory look. This was far less work than drilling thousands of spot welds to use the good panels on a rusty car.
I learned how to do body work on wrecked cars. Doing clip, rad supports etc. So this was really no different than that. When it's done it will look just like any other 2 door and you'd really have to look to tell it was a 4 door... or look at the vin laugh2
#1832256 - 05/22/15 01:34 PM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
70440+6bbl Offline
Loc: NY
Wait, who's this fool that "talked" you into that car???
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
#1832522 - 05/22/15 09:01 PM Re: 69 Belvedere 4 door to 2 door conversion [Re: 70440+6bbl]
RUNCHARGER Online   content
Loc: Chilliwack B.C. Canada
Ha! At first I thought yeah that guy is nuts. But really this is a great project and another 69 stays on the road. Kudo's!
Sheldon
Sheldon
#1832635 - 05/23/15 12:09 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: 70440+6bbl]
The same guy who told me to put the pipe down I was smoking when I said I was going to do this laugh2
#1832637 - 05/23/15 12:12 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: RUNCHARGER]
Sheldon
When I was all in pieces I felt like I was nuts. Had it been solid and not needing rust repair, I probably would have left it a 4 door. But 2 of the 4 doors are damaged, floors front to back and the rear window opening was shot including the corner sections that are part of the quarters. Then the package tray was all hacked up too.
#1833485 - 05/24/15 08:14 PM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
peabodyracing Offline
Loc: Minnesota
You're a better man than I. I'd have bet money you couldn't convert that vintage. Whole lot more difficult than the early-mid 60's b bodies. Well done!
Lead, follow or get the hell out of the way
#1833531 - 05/24/15 09:20 PM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
Your not the only one who thought that. I have plenty of b-bodies around to look at plus built quite a few over the years... so did all my research by comparing them on my own. I couldn't find much info on the differences. There are more things I got to do to finish the conversion, like the rockers dip in where the post previously was. But the hard parts definitely done. Now to get some other cars done in the shop, so I can get it inside and do some body work.
#1851005 - 06/17/15 10:09 AM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
skicker Offline
Son of Doc Fiberglass
Loc: Western Md.
SW PA isn't too far for me...I may have to ride up and check this out...As you found out its much easier to hack up something with no real value than something rare and original...Nice Job thus far... up
Loving all the tears... bawling
Sorry Doc...
We'll try again in 2 years...up
Edited...Looks like it will be 6 years...biggrin
#1851280 - 06/17/15 06:12 PM Re: 69 Belvedere 4 door to 2 door conversion [Re: Silver70]
booger Offline
Loc: Up a holler, down a crick
A frankenbee sold on ebay once, they'd split a superbee horizontally to get rid of lower body rust and welded that to the bottom from a 4-door.
It has a WM23M9A VIN on it when finished.
Edited by booger (06/17/15 06:12 PM)
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
25,702 Registered Members
196,789 Topics
57 Belvedere - a few fixes
by mopardwh
01/20/19 11:46 PM
Anyone else watching the lunar eclipse tonight?
by Alaskan_TA
01/20/19 10:56 PM
Any Ford Techs on here?
by oldjonny
01/20/19 10:06 PM
Hot Rod Power Tour 2019 (MoPowered Tour)
by Devil
01/20/19 09:53 PM
