Page 3 of 3 1 2 3
Re: 12s in a challenger with a stock bottom 340? [Re: cudadoug] #1831108
05/20/15 09:58 PM
05/20/15 09:58 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted By cudadoug
Originally Posted By pittsburghracer
It ran 11.82 with a slightly better engine when I owned it and it was still on the street.
Describe this better engine that you speak of...
I built a 340 with 11.5-1 Direct Connection pistons, 590 lift solid cam, and a portasonic intake manifold.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 12s in a challenger with a stock bottom 340? [Re: joes68340s] #1831109
05/20/15 10:00 PM
05/20/15 10:00 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
The trick with the 340 is 12s on a reasonable street gear. Most of these builds are 360s and have the street gear with the low end torque. All my 340s needed at least 3.91 and rpm to hit 12s however mine were with old school cams and unported heads big difference in the newer cams. I have a AAR Cuda I want to set up with a stock stroke 340. Will not run the Six Pack.
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1831437
05/21/15 02:10 PM
05/21/15 02:10 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
What kind of fuel system do you guys use to support these combos?
RMNS 10:9-10
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1831448
05/21/15 02:25 PM
05/21/15 02:25 PM
USA
B3RE Offline
B3RE  Offline
USA
Carter Street mechanical pump, 3/8" fuel line and pickup. Nothing fancy.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: 12s in a challenger with a stock bottom 340? [Re: B3RE] #1831476
05/21/15 02:53 PM
05/21/15 02:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
stock 5/16 would even work, but if you are starting from scratch, just go w/ 3/8 just in case you upgrade later.
Re: 12s in a challenger with a stock bottom 340? [Re: Mr.Yuck] #1831484
05/21/15 03:02 PM
05/21/15 03:02 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I run stock 5/16 line on my Duster, best so far in my signature. Pretty sure I will get it in the 11.50's with just tuning. Haven't really touched it yet. Getting rid of the power steering, factory fan and water pump and going manual steering, electric fan and water pump might get it under that, but then it would need a cage.... Don't want that for this car. Only had it out twice so far and just wanted to race it, as it got done late last summer..... This year more tinkering.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1831814
05/21/15 11:15 PM
05/21/15 11:15 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
OE 5/16 line and a HP mech pump will move enough fuel to go pretty fast. Bonus: Look STOCK. Remember, no matter how much pump and line you have, it's metered by the needle and seat.
Where's Dwayne Porter these days? Mid 10's with a roller 440 in a Satellite with mech pump and the OE 5/16 line.
L O L ! ! !
Re: 12s in a challenger with a stock bottom 340? [Re: skicker] #1831983
05/22/15 08:56 AM
05/22/15 08:56 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted By crackedback
A 360, j head with an xe268H in a Demon can run 12.50's or better in the right hands.
Takes work to fine tune the combo and with an auto, the converter is key.
Truth. I had a 360, mildly worked J head, XE268, LD340, 750 vac sec.
Ran 12.75 in a daily driven Dart with a stock ~2200rpm stall and 3.23's. Ran 12.75 @ 107 in good air. Car sat for 8 years, went through it and ran 12.9 @ 105 in the heat of the summer.
Same sluggish 1.9 60' laugh2
First time out playing with spray, on a nasty day went from 13.3 @ 104 to a 12.18 @ 116 on a 47 jet, not hitting it til 100' out.
Originally Posted By skicker
I've come to the disappointing conclusion I probably can't hit the 12's with a 3.23 gear. frowwn Car feels good but I think its at about the 13.30's. shruggy 3.91 gears are ready to go in...that should do it up but I'm on the fence since a newer design looser convertor may work better...maybe something in the 4500 range... work
You can get there, just takes a well matched combo. I went through the gear/converter debate many times. I prefer the street manners of the stock converter and 3.23's.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1832609
05/23/15 01:09 AM
05/23/15 01:09 AM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
How well would an m1 work
RMNS 10:9-10
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1832630
05/23/15 01:59 AM
05/23/15 01:59 AM
Q
Quicktree Offline
Quicktree  Offline
Q
didn't read the whole thread but we have done it with a stock 340 other than the cam which was a comp cam 305/525 with an M1. still have the motor. it ran 12.48s at 107mph if i remember correctly
Re: 12s in a challenger with a stock bottom 340? [Re: DartS] #1832633
05/23/15 02:02 AM
05/23/15 02:02 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Originally Posted By DartS
My buddies 73 Challenger 340 with auto weighed 3500 when he had it weighed.
that is exactly what out 70 challenger weighed,
Page 3 of 3 1 2 3
