Chrome moly welding #183182
01/03/09 11:22 PM
01/03/09 11:22 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
I've got a pair of steel 1350 drive shafts yokes and was going to order a chrome moly 3" driveshaft tube from summit for them.
What mig wire should I use? Standard .035 solid steel/copper or something else? Is it not adviseable to weld chrome moly to steel?
Re: Chrome moly welding [Re: NTOLERANCE] #183183
01/04/09 04:16 AM
01/04/09 04:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I thought that chrome moly had to be TIG welded,,
I am truckless..
Re: Chrome moly welding [Re: NTOLERANCE] #183184
01/04/09 07:24 AM
01/04/09 07:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You can buy CM wire for your mig or use carbon steel wire above 70,000 tensile strength.The weld with tig only process is for rollcage.We tig a lot of rearends and shafts as well as other componants at customers request.
Re: Chrome moly welding [Re: B G Racing] #183185
01/04/09 10:08 AM
01/04/09 10:08 AM
Madison Wi
Madison Wi
Thanks Bob.
And there isnt any problem welding the CM to the steel yokes?
Re: Chrome moly welding [Re: NTOLERANCE] #183186
01/04/09 10:15 AM
01/04/09 10:15 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm curious, what grade steel are you using, 4130?
Re: Chrome moly welding [Re: 6PakBee] #183187
01/04/09 11:18 AM
01/04/09 11:18 AM
New York
K
Ken25 Offline
Ken25  Offline
K
New York
i've been a welder pipe fitter for along time and perfer tig. 70 series is the best i've found for 4130. i've built several flattrack atv chassis and never seen a broken weld. my current quad is 289# with fuel and dyno's about 103 at the wheel. on a 1/2 mile i can turn faster times than a big block mod.mig welding works good. 200-250 pre heat to get the moister out. just dont cool it down to fast and get it cherry red.
Re: Chrome moly welding [Re: 6PakBee] #183188
01/04/09 11:54 AM
01/04/09 11:54 AM
Madison Wi
Madison Wi
I dunno, it doesnt say.... here is the yoke:
http://store.summitracing.com/partdetail.asp?part=STR%2DU1670&FROM=MG
I was going to order this tube:
http://store.summitracing.com/partdetail.asp?part=STR%2DU1700T&FROM=MG
Maybe I should just run a steel one. I dont think I've got enough power to break a complete steel drive shaft, with steel yokes and 1350 joints.
If I were to run steel, what thickness material should I use?
Re: Chrome moly welding [Re: NTOLERANCE] #183189
01/04/09 12:17 PM
01/04/09 12:17 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I looked on the Strange website and it is 4130. Pretty low alloy, 1% Cr, 0.25 % Mo. I did a brief websearch on welding techniques for 4130 and found a bunch. You should be in good shape. Good luck.
