Chrome moly welding
#183182
01/03/09 11:22 PM
01/03/09 11:22 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I've got a pair of steel 1350 drive shafts yokes and was going to order a chrome moly 3" driveshaft tube from summit for them.
What mig wire should I use? Standard .035 solid steel/copper or something else? Is it not adviseable to weld chrome moly to steel?
Re: Chrome moly welding
[Re: B G Racing]
#183185
01/04/09 10:08 AM
01/04/09 10:08 AM
NTOLERANCE
Madison Wi
Thanks Bob.
And there isnt any problem welding the CM to the steel yokes?
[Re: NTOLERANCE]
#183186
01/04/09 10:15 AM
01/04/09 10:15 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I'm curious, what grade steel are you using, 4130?
[Re: NTOLERANCE]
#183189
01/04/09 12:17 PM
01/04/09 12:17 PM
6PakBee
North Dakota
I looked on the Strange website and it is 4130. Pretty low alloy, 1% Cr, 0.25 % Mo. I did a brief websearch on welding techniques for 4130 and found a bunch. You should be in good shape. Good luck.
