Dana 70 rebuild...bearing question?
#1830217
05/19/15 06:00 PM
05/19/15 06:00 PM
Posts: 13,379 Marion, South Carolina [><]
an8sec70cuda
Had to rebuild the Dana 70 in my '01 2500 last week. I noticed the pinion seal leaking after my last trip to the track towing my 24' enclosed trailer. Turned out to be worn pinion bearings and the carrier bearings needed replacing also. R&P looked great. The bearings I took out of it were KOYO bearings. Were these used from the factory? I'm wondering if this rear had been gone through prior to me owning the truck. It has 197k miles on it now, had 164k when I bought it.
Re: Dana 70 rebuild...bearing question?
[Re: an8sec70cuda]
#1830331
05/19/15 09:21 PM
05/19/15 09:21 PM
Posts: 684 Maine
jerseybud
Maine
Koyo bearings were in my 93 dana 70 too, but it had been rebuilt. My 92 totally stock dana 60 had timkens.
I knew the 93 had been rebuilt b/c the date code on the limited slip carrier was 1997.
[Re: an8sec70cuda]
#1830641
05/20/15 10:20 AM
05/20/15 10:20 AM
an8sec70cuda
I guess I'm surprised this rear needed the bearings replaced before 164k miles. I know the 1/2 ton trucks in the '90s and early 2000s had rearend issues, just figured this big ole dana would have lasted longer. Of course, for all I know, this truck may have had a big trailer behind it for all of the 164k miles that were put on it before I got it.
[Re: an8sec70cuda]
#1830762
05/20/15 01:36 PM
05/20/15 01:36 PM
an8sec70cuda
[Re: 135sohc]
#1831745
05/21/15 09:53 PM
05/21/15 09:53 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
One of the Dana 60s that I built recently had to have the inside of the case machined where the carrier bearing cup fit in the housing because it had spun under stress. That seems to be a common issue in high mileage and heavy duty use. My answer to that is to be very careful in the pre-load setup and to use synthetic gear oil with a large capacity cover for more gear oil. I wish I was building a S60 with the adjustable carrier bearings, but I build what I have.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: an8sec70cuda]
#1832012
05/22/15 10:04 AM
05/22/15 10:04 AM
an8sec70cuda
Rhino...Needing bearings every 100k miles seems excessive to me. I guess if you do nothing but tow heavy loads that would be reasonable.
No races spun in mine, just generally worn out bearings...pitted rollers and grooved races. Everything went back together nice and tight.
Thanks for the info yall.
[Re: TJ2]
#1834267
05/26/15 12:13 AM
05/26/15 12:13 AM
Posts: 43,603 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Interesting! I lived in Columbia, MO in 1969 and my sister still lives there. Where is the plant located?
JB Rhinehart, Realist
A-Body's RULE!
