Re: 12s in a challenger with a stock bottom 340?
[Re: cudadoug]
#1831108
05/20/15 09:58 PM
05/20/15 09:58 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It ran 11.82 with a slightly better engine when I owned it and it was still on the street. Describe this better engine that you speak of... I built a 340 with 11.5-1 Direct Connection pistons, 590 lift solid cam, and a portasonic intake manifold.
[Re: BLACK71]
#1831437
05/21/15 02:10 PM
05/21/15 02:10 PM
Posts: 54 US
BLACK71
US
What kind of fuel system do you guys use to support these combos?
RMNS 10:9-10
[Re: BLACK71]
#1831448
05/21/15 02:25 PM
05/21/15 02:25 PM
Posts: 561 USA
B3RE
USA
Carter Street mechanical pump, 3/8" fuel line and pickup. Nothing fancy.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#1831476
05/21/15 02:53 PM
05/21/15 02:53 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Carter Street mechanical pump, 3/8" fuel line and pickup. Nothing fancy. stock 5/16 would even work, but if you are starting from scratch, just go w/ 3/8 just in case you upgrade later.
[Re: Mr.Yuck]
#1831484
05/21/15 03:02 PM
05/21/15 03:02 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Carter Street mechanical pump, 3/8" fuel line and pickup. Nothing fancy. stock 5/16 would even work, but if you are starting from scratch, just go w/ 3/8 just in case you upgrade later. I run stock 5/16 line on my Duster, best so far in my signature. Pretty sure I will get it in the 11.50's with just tuning. Haven't really touched it yet. Getting rid of the power steering, factory fan and water pump and going manual steering, electric fan and water pump might get it under that, but then it would need a cage.... Don't want that for this car. Only had it out twice so far and just wanted to race it, as it got done late last summer..... This year more tinkering.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: BLACK71]
#1831814
05/21/15 11:15 PM
05/21/15 11:15 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
What kind of fuel system do you guys use to support these combos? OE 5/16 line and a HP mech pump will move enough fuel to go pretty fast. Bonus: Look STOCK. Remember, no matter how much pump and line you have, it's metered by the needle and seat. Where's Dwayne Porter these days? Mid 10's with a roller 440 in a Satellite with mech pump and the OE 5/16 line. L O L ! ! !
[Re: skicker]
#1831983
05/22/15 08:56 AM
05/22/15 08:56 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
A 360, j head with an xe268H in a Demon can run 12.50's or better in the right hands.
Takes work to fine tune the combo and with an auto, the converter is key. Truth. I had a 360, mildly worked J head, XE268, LD340, 750 vac sec. Ran 12.75 in a daily driven Dart with a stock ~2200rpm stall and 3.23's. Ran 12.75 @ 107 in good air. Car sat for 8 years, went through it and ran 12.9 @ 105 in the heat of the summer. Same sluggish 1.9 60' First time out playing with spray, on a nasty day went from 13.3 @ 104 to a 12.18 @ 116 on a 47 jet, not hitting it til 100' out. I've come to the disappointing conclusion I probably can't hit the 12's with a 3.23 gear. Car feels good but I think its at about the 13.30's. 3.91 gears are ready to go in...that should do it but I'm on the fence since a newer design looser convertor may work better...maybe something in the 4500 range... You can get there, just takes a well matched combo. I went through the gear/converter debate many times. I prefer the street manners of the stock converter and 3.23's.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: BLACK71]
#1832609
05/23/15 01:09 AM
05/23/15 01:09 AM
Posts: 54 US
BLACK71
US
How well would an m1 work
RMNS 10:9-10
[Re: BLACK71]
#1832630
05/23/15 01:59 AM
05/23/15 01:59 AM
Quicktree
How well would an m1 work didn't read the whole thread but we have done it with a stock 340 other than the cam which was a comp cam 305/525 with an M1. still have the motor. it ran 12.48s at 107mph if i remember correctly
[Re: DartS]
#1832633
05/23/15 02:02 AM
05/23/15 02:02 AM
Quicktree
My buddies 73 Challenger 340 with auto weighed 3500 when he had it weighed. that is exactly what out 70 challenger weighed,
