Re: disc brake spindle question - b body [Re: 340duster340] #183086
01/05/09 08:13 AM
01/05/09 08:13 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
This discussion comes around every couple of months or so.
Link to previous discussion
Re: disc brake spindle question - b body [Re: nomore65BelvJim] #183087
01/05/09 10:30 AM
01/05/09 10:30 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
So who do we believe on the 73 up B body spindles, I have heard they can be dangerous with an earlier car swap.
73 up F,M,J and B are fine for the swap.
Where did you "hear" it was dangerous? Have you ever actually known of someone having issues with the swap? I havent and neither has anyone I know who has done it or knows someone else who has. You'd think if it was such a dangerous thing it would be well documented with accident reports and such, but its not. Go figure
I'm working on another brake swap in the shop now, a 74 Satellite disc set-up installed on a 72 Demon
I read a magazine article several years ago advising against using those spindles,thats all I think it was the same article posted above. I take offence that you imply I made up it could be dangerous I'm just trying to sort out the facts since there is a lot of miss information out there.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: disc brake spindle question - b body [Re: mopargem] #183088
01/05/09 10:38 AM
01/05/09 10:38 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
I was questioning your source is all, not implying anything. Everyones fear of the swap seems to come from that same article yet there is no report of someone actually having a problem who has done it.
Re: disc brake spindle question - b body [Re: mopargem] #183089
01/05/09 04:26 PM
01/05/09 04:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Every time you hear that sentiment, ask if anybody has a verifiable case of the tall spindle causing a failure or incident.
Re: disc brake spindle question - b body [Re: John_Kunkel] #183090
01/05/09 05:31 PM
01/05/09 05:31 PM
O
OLD318 Offline
OLD318  Offline
O
BEEN THERE...DONE THAT...
Instead of worrying about whether or not you have the right donor car etc...
I would recommend that you at least consider the kit from Master Power brakes.
It's not just the spindles, shields, your going to have to grab from the donor car...to make the
system work...
I've already been through this on my 70 Coronet.
my recommendation based on my experience doing this (I did the 73-76 A-Body swap) ...
Just buy the complete kit
INCLUDING the booster and master cylinder
AND plumbing from Master Power brakes...
It's based off of the 73-76 A-body conversion anyway!
The difference is:
You can get it all from one place along with
tech support which is very good BTW...
or
You can go piece by piece and fiddle and fool with old donor cars and parts stores...
In the end, you can't do it any cheaper,
any easier or get any better results
than if you just buy the kit.
If I had to do another one, I would buy the kit
in a heartbeat...
Again, been there, done that!
Just my 2 cents... FWIW...
Best of luck to you either way!
Re: disc brake spindle question - b body [Re: John_Kunkel] #183091
01/05/09 05:41 PM
01/05/09 05:41 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Sorry Jim if I sounded defensive, my wife passed away November 3rd and I have been a little on edge ever since. My 74 Charger has become a parts car and I would love to swap all the disc brake stuff over to my 70 Challenger. Would like to here more from folks who have made the swap with the tall spindles. Also John Kunkel I always highly respect your knowledge, thanks for your input. Tim
Re: disc brake spindle question - b body [Re: OLD318] #183092
01/05/09 07:34 PM
01/05/09 07:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And the cost versus junk yard parts?
The whole idea of using junk yard/donor car parts is to avoid the cost of "store bought" kits.
Re: disc brake spindle question - b body [Re: John_Kunkel] #183093
01/06/09 03:27 AM
01/06/09 03:27 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Rick Ehrenberg -
If you are referring to the same one I saw, the chart showed almost triple the bump steer, which coincided pretty well with the tests I made years back.
I was, and still am, dead set against this swap. I hate bump-steer...I like to drive fast on lousy roads!
There are lots of cars that perform pretty well with less-than-perfect suspension / steering geometry. In fact, virtually every design is a compromise. I just fail to see the rationale behind a deliberate downgrade, esp. when the correct parts are not hard to procure.
One of the first years I ran the One Lap of America in my Valiant, two guys - great guys - from western Canada showed up in a pink Charger. They had the tall knuckles, calipers swapped, and I noticed the brake hoses were way too short and/or misrouted. I helped them fix that before the event began.
They claimed that the car had "perfect alignment". And it seemed fine on the highway sections. But on the track, they spun the car, went off, etc., repeatedly. I've always wondered how much of their grief was due to large amounts of bumpsteer.
While I have no idea whom the guy is who did the measurements, presumably, since he was (I'm told) trying to build a case for the tall knuckles, it stands to reason that if it was fudged, it would been fudged in the other direction!
Picture an imaginary knuckle where the upper section had been made, say, 10 inches taller (also see diagram way up in this thread). Nothing else changes. Now the UCA is at a bizarre angle (no longer approx. perpendicular to the steering axis (ball joint axis), and the top of the knuckle moves in and out along what's now a crazy arc that moves the upper ball joint way in and out from jounce to rebound. Camber changes, bigtime, right? And what happens to toe during the travel? Ta-dah!
In another everyday example: Go get your front end aligned. What's the last adjustment they make? Right! Toe! That's because ANYTHING that changes camber will change toe.
Chrysler's engineering credo for these cars (published) was:
"...at some acceptable caster / camber setting, the amount of toe change can be set or corrected to zero which will yield an ideal toe patten.”
Why screw with that? While there are zillions of instances where aftermarket parts far surpass OEM stuff (and the reverse is equally true!), there are no re-engineered aftermarket knuckles – only ones where the spindle has been moved. Jeez. These cars had MUCH better - DEMONSTRABLY better - geometry (not to mention torsional rigidity, unsprung weight, strength, etc.) than their contemporary competitors. Why screw that up?
I’ll give somebody (or everybody) else the last word. I’m done!
Cited HERE
CompSyn
Re: disc brake spindle question - b body [Re: CompSyn] #183094
01/06/09 02:42 PM
01/06/09 02:42 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
So...
The over travel on the upper ball joint theory has been proven to NOT be an issue?
If it's a bump steer issue why can't the tie rod heights/angles/lengths be adjusted to tune out the toe change?
Re: disc brake spindle question - b body [Re: mopargem] #183095
01/06/09 03:44 PM
01/06/09 03:44 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
...my wife passed away November 3rd and I have been a little on edge ever since. My 74 Charger has become a parts car and I would love to swap all the disc brake stuff over to my 70 Challenger. Would like to here more from folks who have made the swap with the tall spindles.
Sorry to hear about your wife.
I put '74 Charger discs on my '72 RR back in '76, and they were on there for over 25 years and 50,000 miles with no problems. No ball joint issues, no steering issues. I'm doing something different now, but I wouldn't worry about the swap you're contemplating.
-Marq
Re: disc brake spindle question - b body [Re: MoparMarq] #183096
01/06/09 04:11 PM
01/06/09 04:11 PM
AndyF Online content
AndyF  Online Content
I recommend the late model FMJ knuckles along with Firm Feel tubular upper control arms to anyone who is running my 13 inch brake kit. The late model FMJ knuckles are the lightest knuckles even though they are the tall design. We've been running the taller knuckles on a variety of road race and track cars and they seem to work just great.
If I had more resources I'd design an even taller knuckle for serious Mopar corner carvers. This whole area is one where the Mopar crowd is about 20 years behind the GM crowd. I really figured that by the time we got to 2009 that the aftermarket would have a good quality forged knuckle for the Mopar front end but it still hasn't happened. There should be a bolt on kit with tall knuckles, drop heights, bolt on big brakes, etc. All of the technology is available, just needs to be put together by a vendor.
Re: disc brake spindle question - b body [Re: CompSyn] #183097
01/06/09 06:38 PM
01/06/09 06:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rick Ehrenberg - I've always wondered how much of their grief was due to large amounts of bumpsteer.
The fact that he "wondered" kinda eliminates "verifiable incident" challenge. Could just as easily be a classic case of "High performance car but low performance driver".
Take note that a (former?) member of this board was running a road race E body with the tall spindles purposely because they improved the handling.
Also, do the math, the tall spindle changes the angle of the upper control arm 2.7°, with the amount of adjustment in the cam adjusters it's possible to achieve that with stock spindles.
Re: disc brake spindle question - b body [Re: 340duster340] #183098
01/06/09 09:41 PM
01/06/09 09:41 PM
I remember when Eberg wrote/published his article against using them & it was an excellent piece of journalism that actually scared me to death of ever using them . Then there started to be feedback from people who were using them & some were against them but many were using them & were touting their advantages.
