Power Steering Way Too Easy #1830782
05/20/15 01:58 PM
05/20/15 01:58 PM
Shelby, Ohio
JeffL Offline OP
JeffL  Offline OP
Shelby, Ohio
Is there a way to adjust the "feel" of my power steering. The steering is so easy. You can steer it with your pinky finger. I believe my steering gear is from a c body. Picture of pump and gear below. Is the pulley system causing any issues? Thanks much for any input. up
Re: Power Steering Way Too Easy [Re: JeffL] #1830806
05/20/15 02:27 PM
05/20/15 02:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is, it involves a change in the output of the pump , ebooger has an article on it
http://www.moparaction.com/tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
Re: Power Steering Way Too Easy [Re: JohnRR] #1830837
05/20/15 03:07 PM
05/20/15 03:07 PM
Shelby, Ohio
JeffL Offline OP
JeffL  Offline OP
Shelby, Ohio
Thanks so much!
Re: Power Steering Way Too Easy [Re: JeffL] #1830950
05/20/15 05:28 PM
05/20/15 05:28 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I did that mod of my Fifth Avenue a couple years ago. It helps, but it still wasn't enough for me. I wound up picking up a Borgeson box from Bergman Autocraft; which I have yet to install, but hope to have it done in a couple weeks here.
Re: Power Steering Way Too Easy [Re: JeffL] #1830964
05/20/15 05:51 PM
05/20/15 05:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stock power steering is pretty much one pinky required for feel.
Don't be the exception.
