Re: Should a carb swap from one engine to another?
[Re: Airwoofer]
#1830710
05/20/15 12:23 PM
05/20/15 12:23 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Have you checked for vacuum leaks?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Airwoofer]
#1830765
05/20/15 01:41 PM
05/20/15 01:41 PM
Posts: 19,370 Las Vegas
Al_Alguire
Las Vegas
Lots of reasons. Signal strength, venture and booster size will change how the fuel is pulled, engine manifold vacuum, jetting and bleed package etc etc. If it was a simple as bolting it on and it working great there would not be so many choices out there.
[Re: Airwoofer]
#1830960
05/20/15 05:38 PM
05/20/15 05:38 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
That's what I thought. No, I got all the gas outta the carb and it has sat for over a year. Very well could be the motor, or plug wires, or a bad plug. All of the header tubes are hot so I think they are all firing. This is the first time this pile of parts has ever ran.
I have a gen 3 1150? Dom I will try tonight. I got it new from Holley on fleabay way too cheap so it is probably not calibrated properly.
[Re: Airwoofer]
#1831473
05/21/15 02:51 PM
05/21/15 02:51 PM
Airwoofer
Huntsville, AL
My heads and valve covers seem to get kinda warm also compared to the water coming out of the block. This better be a simple fix like getting clnc between the balancer and the front cover. I'm anxious to get the thing where I can drive it on the trailer, get mufflers put on, and do a big fat burnout and seating in the rings.
Got's the need for speed.
[Re: Airwoofer]
#1834542
05/26/15 02:10 PM
05/26/15 02:10 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Glad you found the problem. I'd change timing covers instead of having to use a balancer spacer and then having to realign the belt and pickup.
