Re: Edelbrock 1411 lean issues on 440
[Re: chermik1999]
#1830720
05/20/15 12:38 PM
05/20/15 12:38 PM
RapidRobert
what idle speed? still on idle circuit? check integrity of needle/seats/float saturation/fuel psi at carb. make sure the rods are down at idle & might bump the initial up to 18-20 & see what that does for it & yes that'd push you total likely too high but just stay at idle with it at 18 & work there & see what develops (cuz idle is where the prob is). yes the 1411 is the eddy 750 that gets all the flak but work with it & holler how it goes. I have one I bought for $25 but I ain't got to it yet. (the 25 shoulda been a red flag but I feel lucky) EDIT you mentioned lean misfire, not sure about that but I'd block the rods up for that & see what happens & what were the idle A/F readings again
[Re: chermik1999]
#1830825
05/20/15 02:53 PM
05/20/15 02:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sounds like a miss to me. Got a cylinder not firing at idle? That would make it rich smell, but lean AF if I am thinking right.
[Re: chermik1999]
#1830864
05/20/15 03:41 PM
05/20/15 03:41 PM
Posts: 12,087 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Do you know anyone that might have a carb that they would lend you just to see if the problem remains with the loaner? How about pulling plug wires one at a time at idle to see if you have a dead or weak cyl at idle?
You need to determine whether the problem is the carb or the engine itself before doing anything else.
One last thing, do not worry about any particular A/F ratio at idle. I see good idles anywhere from 13.5 to 14.5. The idle ratio doesn't matter, just tune for what the engine likes. Of course, if the idle mix is way off, then the O2 can tell you which way to go. If it has a mild cam, then a vacuum gage works good or you can just tune it using a good low RPM tach.
Master, again and still
[Re: Mr.Yuck]
#1830972
05/20/15 06:00 PM
05/20/15 06:00 PM
RapidRobert
use your light to see if each one is firing rather than pulling a wire. electronics dont like opens. grounding each wire WO pulliing it works
[Re: chermik1999]
#1831271
05/21/15 01:29 AM
05/21/15 01:29 AM
Posts: 10,213 Someplace you aren't
SomeCarGuy
That lean at idle with two different carbs points to a vac leak. Check the intake and power booster if it has one.
I want my fair share
[Re: chermik1999]
#1831292
05/21/15 03:29 AM
05/21/15 03:29 AM
Posts: 61 Alberta, Canada
chermik1999
Alberta, Canada
I bought this car last Sept. is a 68 RR, first gen (1st 6mos of build) The guy said runs great....I knew it needed work with these issues, but I've had SB's for years, and thought no big deal. Well been a week now...lol. But i'm sure I'll get it. Love the car as what it needed was just final details and touch-ups. Oh ya...paint too...paint is good from far but far from good if you know what I mean...lol. I paint in my shop anyway, so will cut and polish for now until winter. Then B/C and color sand/polish for a perfect finish later.
I did read one thread quoting either Rick here or Barry Grant about lean misfires diagnosed as rich when actually are a lean condition. That's why leaning toward this route. When I played with the 750 long enough, I thought I'd try the 800. It was marginally better but still not where it should be. So yes, I still have underlying issues.
Also forgot, one muffler is shot...blown a hole in it. That's coming as well soon (Jegs BO). That wouldn't do that would it?
Good catch somecarguy. No power brakes, but will check for leaks. Dyno on 2007 sheet shows 14hg at 800 rpm from Year One, but we all know those were not real all the time. Sure not getting that reading today.
Mr Yuck and Robert, good points as well. I didn't know a timing light on each wire would tell you if it's firing or not. See...not too old to learn something new....even from Canada ey....lol. Also the blocking up of the rods. If it still read stupid lean, then I have major issues....GOOD ONE!
When back Monday, will do a dry/wet comp and check again for vacuum leaks. ran unlit propane around base but found none. Will try again.
At initial timing of 14 deg, did a run and got some pinging when moshed it, but cleared up after tires stopped spinning...lol. So I know it's lean...
Have as I said one of those Asian Procomp dist and I'm sure isn't working properly. When mech advance is at 34 deg @ 2500 - 3000 rpm, back at idle it's like 9 deg. Bump back up to say 14 at idle, and goes over bad. Then changes again...so think that junk has to go. So that thing is not running right either. Have the MSD all in one enroute from Jegs coming soon. It's fully adjustable and has a built in rev limiter as well. Has capability to stop advance at a specified RPM. Will change that, plug wires and plugs. Comp test, reset timing and then carb. Then will check again.
So keep the ideas coming if I am missing something. Be mid - end of next week with results, so stay tuned. Thanks again!
cheers - Mike
[Re: chermik1999]
#1832139
05/22/15 01:23 PM
05/22/15 01:23 PM
chermik1999
Alberta, Canada
Sensor on one side but its the same on both. Plugs aren't black anymore, light brown to light grey. Im going to change them to get a better reading as they have been in for a while, When they were black, they cleaned up after the dist change and tweaking the carbs.
Vac advance is hooked up. So yes, will disconnect it and I'll try propping up the rods at idle as well. Then take a reading again. Fuel pressure is stock but tested that and was at 5-6 I believe. Floats set a few times, but stayed steady at 7/16" so looks ok there as well.
Aside for the richness at idle, had I not had an AFR meter, I would have left it running as is. Runs good off the line, mid a WOT. Little pinging, but was waiting to change the dist. I have read that the procomp dists have many issues. Boought this one off Ebay from Skip White. Says it was set at 20 deg max advance, but funny thing. He doesn't sell them anymore. So what can I say.
I'll do the changes next week as the parts should be in. I'll get to the bottom of this, with all your help as well ....thanks guys.
--Mike
