Re: head studs for alum. bolck
[Re: bonefish]
#1830698
05/20/15 11:59 AM
05/20/15 11:59 AM
Posts: 2,646 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
should the head studs for a alum. block have a longer thread engagement than for an iron block? You should use the studs designed for the block and yes they might have much more engagement.
2011 Drag Pak Challenger
[Re: rickseeman]
#1830733
05/20/15 12:50 PM
05/20/15 12:50 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
should the head studs for a alum. block have a longer thread engagement than for an iron block? You should use the studs designed for the block and yes they might have much more engagement. I have a world block and the threads go a little over a inch longer than the bolts.
[Re: camastomcat]
#1831180
05/20/15 11:23 PM
05/20/15 11:23 PM
Posts: 16,925 NC
440Jim
NC
KB is a different animal ... Yea, they are really built. The main caps have studs that are 5/8" in the aluminum block, and tapered to 9/16" through the caps. Way bigger than the factory 1/2" main studs.
