Rear gear ?? #1830587
05/20/15 02:39 AM
05/20/15 02:39 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
So I am going to put a new set of gears in the Duster, currently has howling 3.23. I do drive this one on the street and a little bit of freeway driving. I also drive it to the track to race.
I am looking for input on running 3.90 vs 4.10 gears.
I am running 28" drag radials
I am leaning for the 4.10 as I believe it will run the quarter
quicker,, what say you??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Rear gear ?? [Re: Stroker Scamp] #1830630
05/20/15 09:50 AM
05/20/15 09:50 AM
pennsylvania
poboyengineering Offline
pennsylvania
There is only about 200 rpm difference at 65 mph between the two. (approx. 3200 vs 3000). this assumes no converter slip.
according to the chart on Wallace Racing, there should be approx. a 6% torque increase to the rear wheels with the 4.10 over the 3.90.
Both offer about 25% more than the 3.23.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Rear gear ?? [Re: Stroker Scamp] #1830723
05/20/15 12:41 PM
05/20/15 12:41 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What cam do you have? You just want to make sure you're not screaming the motor through the lights at the big end.
Re: Rear gear ?? [Re: dizuster] #1830860
05/20/15 03:38 PM
05/20/15 03:38 PM
dogdays Offline
dogdays  Offline
Wild A$$ Guess - 3.91s
That ratio has worked for countless Mopars. Plus it's nostalgic.
R.
Re: Rear gear ?? [Re: Stroker Scamp] #1830873
05/20/15 03:49 PM
05/20/15 03:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have always run 3.91s in my street/strip cars. The car is comfortable cruising at 50-55MPH. Personally on my big blocks, I prefer to keep the Rs at or about 3,000 RPMs when cruising for any length of time. Some guys are comfortable with more Rs than that and that might be okay. But at 3,000, my engines have always been okay. A small block might be good with some more RPMs than that, I don't know because I haven't had enough small blocks to know.
Master, again and still
Re: Rear gear ?? [Re: dizuster] #1831125
05/20/15 10:24 PM
05/20/15 10:24 PM
pacific northwest
pacific northwest
The cam is an unknown hyd. little bigger than stock.
At some point in the future I have plans of possibly putting a turbo on this motor, not sure what type of gearing
a turbo would want
Re: Rear gear ?? [Re: dizuster] #1831136
05/20/15 10:37 PM
05/20/15 10:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Quote=dizuster]What cam do you have? You just want to make sure you're not screaming the motor through the lights at the big end. [/quote]sorry I disagree it better be screaming through the lights it a N/A small block.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Rear gear ?? [Re: WHITEDART] #1831695
05/21/15 08:37 PM
05/21/15 08:37 PM
6pkScamp Offline
6pkScamp  Offline
I have 4:10's with 29.5" tires. At 55-60 I'm about 2800-3000 rpm.
Re: Rear gear ?? [Re: 6pkScamp] #1831775
05/21/15 10:34 PM
05/21/15 10:34 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I ran 4.30's with 29's on the street and 28's at the track that was with a 340, When I put the 416 in the i also got rid of the 29's and used just the 28's with the 4.30. it seem a bit much so I switched to 3.91's and I'm happy with this combo. Runs just as fast and a few less R's on the freeway.
gary
