'69 Valiant instrument cluster issue #1830382
05/19/15 10:44 PM
05/19/15 10:44 PM
central Kentucky
moprod Offline OP
moprod  Offline OP
central Kentucky
I have a cluster out of a '69 Valiant, the speedometer is sitting on 40 mph, if you turn it back, it jumps right back to 40.
Could this be a problem with it or is the only way to tell hook it up to a cable to see if it work correctly? Thanks
[img] [/img]
Re: '69 Valiant instrument cluster issue [Re: moprod] #1830396
05/19/15 11:01 PM
05/19/15 11:01 PM
that, open it up & see what you see, might be fixable, might not, that stuff is real delicate
