Prebent 3/8 fuel line for pump to carb? #183025
01/03/09 09:25 PM
01/03/09 09:25 PM
Someplace you aren't
SomeCarGuy Offline OP
Where can I find a prebent line set for a Carter AFB/AVS type carb? From the mechanical pump up to the carb. For BB.
I think the repops are all 5/16. Maybe some source makes 3/8 lines.
I want my fair share
Re: Prebent 3/8 fuel line for pump to carb? [Re: SomeCarGuy] #183026
01/03/09 09:28 PM
01/03/09 09:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As far as I'm aware know one makes a prebent 3/8's line, but if you call Fine Lines direct they will probably make it for you......
Re: Prebent 3/8 fuel line for pump to carb? [Re: 1_WILD_RT] #183027
01/03/09 09:56 PM
01/03/09 09:56 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I'm about to do a Magnum head swap onto my 83, 318 powered truck; I will probably dig out my bender and my flaring tool kit and make my own, I'm putting an AFB on it.
Re: Prebent 3/8 fuel line for pump to carb? [Re: volaredon] #183028
01/03/09 10:20 PM
01/03/09 10:20 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You can get 3/8" lines in various lengths from local auto parts stores that already have their ends flared. All you would have to do is cut to size and bend it with a tubing bender.
Re: Prebent 3/8 fuel line for pump to carb? [Re: 69Cuda340S] #183029
01/03/09 10:25 PM
01/03/09 10:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ditto, evn if you have to buy the bender, it will be cheaper than buying it online
