B&M Trick Shift transmission fluid #1830056
05/19/15 02:23 PM
05/19/15 02:23 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Is this stuff recommended in a TF727 street strip use or normal type F? This will be a B&M transmission with a B&M converter. You know they will recommend it, so I'm looking for your opinions if ya'll know about it. Thanks
Re: B&M Trick Shift transmission fluid [Re: JL2] #1830098
05/19/15 03:26 PM
05/19/15 03:26 PM
an8sec70cuda Offline
Just get Type F.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: B&M Trick Shift transmission fluid [Re: an8sec70cuda] #1830135
05/19/15 04:01 PM
05/19/15 04:01 PM
dogdays Offline
dogdays  Offline
Answering the original question, it should work perfectly in a 727.
R.
Re: B&M Trick Shift transmission fluid [Re: JL2] #1830149
05/19/15 04:16 PM
05/19/15 04:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use it.
Re: B&M Trick Shift transmission fluid [Re: JL2] #1830263
05/19/15 07:51 PM
05/19/15 07:51 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Thank ya'll for the input.
