Re: Richard Ehrenberg Master Cylinder
[Re: KillerBee]
#182982
01/08/09 06:56 PM
01/08/09 06:56 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
If I remember right the ones Ehrenberg sells do not have a retainer to keep the push rod in place. Some were concerned that it is possible for the push rod to fall out of the master cylinder if the brake pedal is bumped or pulled back too far, (this means no brakes) I guess it actually has happend to some people. Ehrenberg's suggested fix was to silicone the push rod into the master cylinder.
when i bought the ebooger master he had the retainer available ???
[Re: JohnRR]
#182983
01/08/09 07:09 PM
01/08/09 07:09 PM
RapidRobert
All I can add is on my 65 dart(73 discs/10"drums) w alum 1&1/8 MC the brakes are inadequate(pedal too hard & not enough braking) but I threw it together cause I needed some transportation & I didn't use an adapter for the MC & the pedal is way too high so maybe that's messing up my leverage here. I just bought the car back so I am going to add a spacer & "Dogfather" on here was kind enough to sell me a set of semimetallic pads that I will try .
[Re: RapidRobert]
#182984
01/08/09 11:19 PM
01/08/09 11:19 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I bought a "Eherenberg" master cylinder and the adapter from Rick a few years ago.Quality product and it will work on your application.I put aftermarket discs on the front of my Demon and all I did was swap the master cylinder and the front brakes and it all bolted up nice and easy.
Someone said you needed a additional prop valve,I used the one in my car,and never added the adjustable one.It stops fine,even at 116 Mph at the track.
I'll also bet good money that R.E. never said to use silicone to hold the pushrod in the master cylinder.Using silicone spray to get the rubber retainer seated fully,that I would believe.
[Re: BDW]
#182986
01/09/09 12:26 AM
01/09/09 12:26 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
you'd lose
https://board.moparts.org/ubbthreads/show...rue#Post4233694
Well I got my response from Rick, and I'm posting that email here for you guys to read.
This is what Rick wrote in his email:
Do it the modern way: RTV.
Install m/cyl. Fill recess w/RTV. Slip pushrod, attached to pedal, into the goo, bottomed. Use bungee cord or weight, to maintian light / moderate pressure. Don't touch for 24 hours.
Done.
Rick
Thank you CNXT! I knew I read that here before. Since you're also in Florida feel free to go pick up Chris2421's "good money" bet.
The pushrod has fallen out of a number of cars https://board.moparts.org/ubbthreads/show...p;vc=1&nt=2
[Re: KillerBee]
#182987
01/09/09 09:03 AM
01/09/09 09:03 AM
Chris2581
Jacksonville, FL
Surpised the hell outta me.I for one would NEVER do that.Come on down for your winnings.
[Re: 4speeds4me]
#182991
01/09/09 04:39 PM
01/09/09 04:39 PM
RapidRobert
The problem(as stated by several purchasers) was that some of his MC's had no recess inside the piston on the back side for that $1.00 neoprene retainer to lock into. In other words the piston in the back was for a power brake setup rather than a manual brake one. this summer I am going to(on the bench ) use some RTV & let it set up & see whats up with this. It does sound hokey(& unsafe ) but I've always(& still do) greatly respected Ebergs knowhow so I am going to cut to the chase & see for myself
[Re: Chris2581]
#182992
01/09/09 05:16 PM
01/09/09 05:16 PM
Posts: 4,733 Florida
BDW
Well let me know what you consider "good money" gas is going back up, so it might not be worth the drive.
[Re: CHRGR69]
#182994
01/10/09 09:57 AM
01/10/09 09:57 AM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
I bought one...works but leaks around the caps. Ruined the paint on the inner fenders.
I told Rick about the caps prior to installing and he sent me 2 different and better quality caps. The ones that come with the M/C don't seat properly.
I noticed that too...
The think leaks like a sieve, I did not realize it was comming out of the caps.
Did you just contact him about the caps? - I bought 3 sets from him and am getting ready to use one on my freshly painted 5 year project and do not want any issues...
Does anyone have the contact for Rick? - I am sure I had it somewhere but I can not find it.
[Re: 6T6Cuda]
#182995
01/10/09 10:47 AM
01/10/09 10:47 AM
Posts: 824 NH
72challorange
He's Game
He's Game
NH
Mine still weeps, been fighting it since the beginning. Trying all sorts of caps and they all seem to distort and leak. I wish He would have just shipped them with the right caps in the first place. My paint was ruined as well. Tom
[Re: CHRGR69]
#182997
01/10/09 02:33 PM
01/10/09 02:33 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
IF you are building a brake system with all new parts, consider going to dot 5 fluid. It will not eat paint. Dot 3 and Dot 5 really arent compatabile, and seals can get "saturated" with dot 3. Should dot 5 be introduced to a dot 3 saturated system, leaks and failures may occur. The equipment I work on uses exclusively Dot 5. Some other techs have put Dot 3 in by mistake. Sometimes thees problem other times, there isnt. Usually I find problem show up from cross contamination a good deal of time later. Flushing a Dot 3 system with alcohol (not the drinkable kind) can produce a clean enough system to run Dot 5. I am in going to run Dot 5 in my 65. All my brake stuff is new. Also going to run it in my hydraulic clutch setup. Doc.
[Re: NTOLERANCE]
#182998
01/10/09 02:53 PM
01/10/09 02:53 PM
6T6Cuda
Cincinnati, OH
Doc.
Ya, that is what I am going to do... but the price of DOT 5 is CRAZY - like $1 an oz (the best price is at autozone of all places).
I have flushed everything out and most of the system is new (front rear lines, M/C, etc) the calipers and wheel cyls are old, but I flushed them with Isopropal & rehoned them and lubed the seals in DOT5. I also blew air through all the old stuff, put Iso in and blew it out as well.
Now on the other car I put Rick's M/C on it does sweat all over the place; I could not figure out where, I guess it is the caps. Need to keep an eye on that.
