ignition box wiring #1829253
05/18/15 03:44 PM
05/18/15 03:44 PM
ont,canada
mopartuner Offline OP
ont,canada
working on a 68 cuda with stock wiring harness.looking for a live that is energized with the key on and key start position.cant seem to find one?
410 pump gas solis flat tappet cam 10.95 so far
Re: ignition box wiring [Re: mopartuner] #1829289
05/18/15 04:19 PM
05/18/15 04:19 PM
there should be aonly one wire is energized in the start position, it goes to the coil side of the rignition resitor to provide 12 volts to the coil when the starter is engaged, it is either brown or blue, CRS disease realcrazy I have a 1969 FSM, not a 1968, that i can look that underhodd schematic up and tell you what color it is in 1969 work I'm pretty sure there the same colors form 1962 and later for the B bodys shruggy
BTW, are you looking for a spare ircuit to use for some other purpose? If so I may not be able to help on that, sorry confused
Re: ignition box wiring [Re: mopartuner] #1829302
05/18/15 04:41 PM
05/18/15 04:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the factory ignition there is none. You'd have to go to an aftermarket ignition that doesn't need the ballast.
Re: ignition box wiring [Re: mopartuner] #1829308
05/18/15 04:43 PM
05/18/15 04:43 PM
ont,canada
ont,canada
I am trying to hook up a msd style box
Re: ignition box wiring [Re: mopartuner] #1829378
05/18/15 06:33 PM
05/18/15 06:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
On the older wiring like you have there is a Start hot wire??? Brown maybe, and a Run hot wire, "Blue" Just tie those Two together coming off the firewall to have a Hot in Both positions.
Re: ignition box wiring [Re: Sport440] #1829396
05/18/15 06:43 PM
05/18/15 06:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep. Eliminate the ballast and tie the wires on both sides of the ballast together and use that as a power source for the small red wire on the MSD box.
Re: ignition box wiring [Re: John_Kunkel] #1830339
05/19/15 09:35 PM
05/19/15 09:35 PM
ont,canada
ont,canada
got it thanks
