2000 Dodge Ram 1500 Coil springs #1829007
05/18/15 09:32 AM
05/18/15 09:32 AM
Murphy, Tx.
V
VitaminC Offline OP
VitaminC  Offline OP
V
Murphy, Tx.
The factory coil springs on my 2000 Dodge Ram 1500 are different sizes, and 2 different tag numbers, 171AA and 172AA. 1 of them is about .030 thicker and maybe 1/4" taller.
Does anyone know which side the taller one goes into.
I've searched and have not found any mention of different size springs, side to side, on my truck.
Brian
Re: 2000 Dodge Ram 1500 Coil springs [Re: VitaminC] #1829018
05/18/15 10:34 AM
05/18/15 10:34 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Typical Mopar convention is even part number = right side of car. Which side would be the taller one? If there is a difference usually the driver side has the taller spring. Driver and fuel tank are on that side.
Re: 2000 Dodge Ram 1500 Coil springs [Re: 73MagDuster] #1829027
05/18/15 10:47 AM
05/18/15 10:47 AM
Murphy, Tx.
V
VitaminC Offline OP
VitaminC  Offline OP
V
Murphy, Tx.
That makes sense, since with 1" drop springs that are the same size, the drivers side is about 3/8-1/2" lower than the passenger side.
Thanks!
