Could my problem be my MSD? #1827970
05/16/15 07:02 PM
05/16/15 07:02 PM
Detroit
Kidsixpack Offline OP
Detroit
A few years ago I added an MSD 6AL to my otherwise stock six pack Bee.
I have no spark. I checked the coil and ballast and they are both good.
Is it my MSD box? How can I test my box to see if it's any good. Is it common for these to fail?
KID
Re: Could my problem be my MSD? [Re: Kidsixpack] #1827973
05/16/15 07:07 PM
05/16/15 07:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You don't use a ballast with an MSD..
And, if you do have any issue with the MSD box, they are really good about taking care of you! My buddy had an odd issue in his ignition system (all MSD) and they just said to send everything in if he liked...so he did..coil, distributor and 6AL. They rebuild the distributor and box (coil was fine) and sent it all back, no charge. up
Re: Could my problem be my MSD? [Re: Kidsixpack] #1827978
05/16/15 07:20 PM
05/16/15 07:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Like stated no ballast with MSD, you should be able to go to MSD's site and look for the trouble shooting section. If I remember you should get a spark when you ground one wire or something.
Re: Could my problem be my MSD? [Re: Kidsixpack] #1827996
05/16/15 07:59 PM
05/16/15 07:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I had this problem about 6 years ago. A wire in the plastic connector out of the box came loose.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Could my problem be my MSD? [Re: 70sixpkrt] #1828041
05/16/15 09:06 PM
05/16/15 09:06 PM
Detroit
Detroit
I've been running with the ballast the whole time and as far as I know I've not had issues. I'll try disconnecting it to see if there is any change.
KID
Re: Could my problem be my MSD? [Re: Kidsixpack] #1828049
05/16/15 09:22 PM
05/16/15 09:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
MSD recommends to bypass the ballast. I doubt that is your issue though but it is worth a try.
Re: Could my problem be my MSD? [Re: mopars4ever] #1828074
05/16/15 10:06 PM
05/16/15 10:06 PM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
Re: Could my problem be my MSD? [Re: Mr340] #1828086
05/16/15 10:29 PM
05/16/15 10:29 PM
Detroit
Detroit
Originally Posted By Mr340
Lots of guidance here! It's going to take me some time. Thanks for all the info guys!
KID
Re: Could my problem be my MSD? [Re: Kidsixpack] #1828098
05/16/15 10:45 PM
05/16/15 10:45 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The biggest problem with MSD boxes is the person that installed it, Most just put a screw in the painted sheet metal for the ground wire. Screw loosens up over time and the box looses ground. Dam MSD box, engine misses and sometimes doesn't run.
Re: Could my problem be my MSD? [Re: Kidsixpack] #1828893
05/18/15 12:19 AM
05/18/15 12:19 AM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
Mine has a light on it that blinks or turns on when it is powered up.. I think you touch the white wire to ground and should see spark. Kevin
71 gtx.....
Re: Could my problem be my MSD? [Re: Kidsixpack] #1829106
05/18/15 12:52 PM
05/18/15 12:52 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I had my MSD box go dead as I mounted it upside down above my glovebox liner on my 70 Charger...damn thing would always buzz too...
There is a shortcut to do ...ask on MSD forums....you short two of the wires and listen for an arc...if you have an arc...you have a good MSD box. Have you checked to make sure the black cable is on a good ground and if your 16ga red wire is actually making contact with keyed 12v?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Could my problem be my MSD? [Re: Kidsixpack] #1829161
05/18/15 02:00 PM
05/18/15 02:00 PM
dogdays Offline
dogdays  Offline
I know some have trouble reading, but MSD has blanketed the Web with wiring diagrams. There is no excuse for having an improperly wired MSD. Well, if you are blind and working alone, then yes there is an excuse. Otherwise, no excuses.
Sounds harsh, but really? There are only six wires, five if you run points. Two to the battery, two to the coil, two to the electronic pickup or one to the points. That's it. The box is grounded by connecting the fat black wire to the battery. DUH!
The procedure for testing is likewise all over the Web. Using the white wire is the easiest for me.
R.
Re: Could my problem be my MSD? [Re: dogdays] #1829318
05/18/15 04:56 PM
05/18/15 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The early MSD instructions ignored the unique Mopar ignition switch with the separate IGN1 and IGN2 circuits so it was easy to mis-wire them.
Box test instructions:
http://www.msdignition.com/page.aspx?id=3206
Re: Could my problem be my MSD? [Re: Kidsixpack] #1832369
05/22/15 06:32 PM
05/22/15 06:32 PM
Detroit
Detroit
Looks like my distributor is to blame. Got another and the car fired right up! I'm really glad the MSD is still working properly.
Thanks for all the input guys!
KID
Re: Could my problem be my MSD? [Re: Kidsixpack] #1832515
05/22/15 10:45 PM
05/22/15 10:45 PM
Any idea on what went wonky in the dist? Does the pickup have continuity? generates ~1 AC volt when cranking?. I'm assuming the gap was still good.
Re: Could my problem be my MSD? [Re: RapidRobert] #1832677
05/23/15 07:59 AM
05/23/15 07:59 AM
Detroit
Detroit
At this point I really don't know. I just swapped it out.
KID
