Re: spark knock after ignition upgrade?
[Re: jd451]
#1828817
05/17/15 10:26 PM
05/17/15 10:26 PM
RapidRobert
X4 something else was changed (which changed your curve). You might plot the curve then toss the old box/coil back in & plot its curve & compare em. reportedly orange (& maybe other) boxes can pull timing so if the HEI did not ( I believe it is good regarding that) then that could (inadvertently) have pushed you over the limit by default
[Re: RapidRobert]
#1828868
05/17/15 11:36 PM
05/17/15 11:36 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
X4 something else was changed (which changed your curve). You might plot the curve then toss the old box/coil back in & plot its curve & compare em. reportedly orange (& maybe other) boxes can pull timing so if the HEI did not ( I believe it is good regarding that) then that could (inadvertently) have pushed you over the limit by default well, i wasnt using the orange box, it was just a parts house cheapo, wondering if they also pulled timing like the orange box because that would explain it! I have not messed with the distributor at all so..
[Re: NITROUSN]
#1828897
05/18/15 12:26 AM
05/18/15 12:26 AM
mopower440
middle Tennessee
well, i wasnt using the orange box, it was just a parts house cheapo, wondering if they also pulled timing like the orange box because that would explain it! I have not messed with the distributor at all so.. So. Get a timing light and see where the timing is. Why play a guessing game when you can verify something critical and basic easily. I will do that, but i was wondering if anyone here knows if all the cheap parts house mopar boxes retarded the timing as well like the MP orange one did..?
[Re: mopower440]
#1829295
05/18/15 04:24 PM
05/18/15 04:24 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
X4 something else was changed (which changed your curve). You might plot the curve then toss the old box/coil back in & plot its curve & compare em. reportedly orange (& maybe other) boxes can pull timing so if the HEI did not ( I believe it is good regarding that) then that could (inadvertently) have pushed you over the limit by default well, i wasnt using the orange box, it was just a parts house cheapo, wondering if they also pulled timing like the orange box because that would explain it! I have not messed with the distributor at all so.. Did you reset your timing after you changed parts ?
[Re: dogdays]
#1829311
05/18/15 04:49 PM
05/18/15 04:49 PM
Andrewh
No mystery to me. Your empirical data seems to show that your Mopar-like box was a little slow on the uptake. You'll have to redo your ignition advance.
"Pulls timing" usually refers to making the spark later and later as engine rpm goes up. In your case as it seems to be doing it right from idle, I'd call it a built-in delay.
R. This. pertronix swap even has a warning on the instructions, that changing it may cause timing changes, even if you didn't do anything else. the part that controls the spark is known to cause timing changes. not a surprise.
[Re: dogdays]
#1830252
05/19/15 07:28 PM
05/19/15 07:28 PM
RapidRobert
I would for sure before I did any changes, plot the 2 curves, if you dont have a dialback you can make marks on the dampener at say 17.5 20 22.5 25 27.5 30 32.5 35. Your timing tab will cover you to 15 then cut/measure a strip of paper with your calipers for a ruler & 0.0632683" is (1) degree & IE 35.5 degrees is 2&1/4" (2.246"). EDIT just note (1) the RPM you reach each point at (2) total degrees (& at what RPM) (3) compare the two. getting a baseline comes first
[Re: mopower440]
#1830355
05/19/15 09:56 PM
05/19/15 09:56 PM
RapidRobert
that definitely explains what caused the pinging! but a box/coil ch would not account for a 10 deg increase in total.. Sumpin else changed: (slots). EDIT but the slots did not change, we're missing something/makes no sense
[Re: RapidRobert]
#1830436
05/19/15 11:42 PM
05/19/15 11:42 PM
mopower440
middle Tennessee
that definitely explains what caused the pinging! but a box/coil ch would not account for a 10 deg increase in total.. Sumpin else changed: (slots). EDIT but the slots did not change, we're missing something/makes no sense no sense at all..lol..sucks i have to tear down the dizzy and do this all over again..
[Re: mopower440]
#1830445
05/19/15 11:48 PM
05/19/15 11:48 PM
RapidRobert
when you get inside the dist as you know holler if you see anything that has changed
[Re: RapidRobert]
#1830475
05/20/15 12:14 AM
05/20/15 12:14 AM
mopower440
middle Tennessee
when you get inside the dist as you know holler if you see anything that has changed Will do Rob! I would just leave it with the initial down to 12-14 but it doesnt seem as strong off the line as it does with the initial up around 18..
