Upper Ball Joint -- A arm Question #1828712
05/17/15 08:15 PM
05/17/15 08:15 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
I assume these are right handed threads ?
I can get them started just a bit by hand,,,but am concerned about stripping the threads on the A arm.
I have the correct socket,,,,and they look to be going in "straight" for the initial thread...
Do I just gently use the socket to screw the ball joint into the A arm ?
Dont want to mess up anything,,,, the ball joint and A arm threads are a bit odd looking compared to the usual style thread I am used to seeing,,,,
thanks for any input....
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1828760
05/17/15 09:13 PM
05/17/15 09:13 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
Yes, they are right hand threads, with the correct socket, just keep tightening them until the ball joint is fully seated. The thread pitch is a bit odd. Key point is to get the ball joint fully seated. Good Luck
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1828772
05/17/15 09:30 PM
05/17/15 09:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Also lube the joint threads to ease installation.
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1828889
05/18/15 12:07 AM
05/18/15 12:07 AM
KENTUCKY
KENTUCKY
Thanks guys !!!
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1828962
05/18/15 03:14 AM
05/18/15 03:14 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Lastly the torque spec is 120 ft/lbs for 70 Challengers.
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1829438
05/18/15 07:25 PM
05/18/15 07:25 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Gentle and Mopar upper ball joints don't usually go in the same sentence from my experience.
The odd looking shallow thread is a kind of a twist in compression fit if I recall correctly. And misthreading or overtightening will more likely result in a cracked A-arm (split radiating from the ball joint hole) than stripping off those threads. Most times I've removed them I needed a three foot pipe on to the 1/2 inch rachet/breaker bar to get them loose. Even with lubricant putting them in will probably feel like a workout.
Get them lined up square, watch closely for them to start to touch seated position, torque as stated, and if they are used A-arms check in a couple days for cracks.
That's my experience, yours may vary.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Upper Ball Joint -- A arm Question [Re: 69CHARGERMD] #1829774
05/19/15 12:55 AM
05/19/15 12:55 AM
Albuquerque
69Boss302 Offline
69Boss302  Offline
Albuquerque
Buy the new reproductions. They come with all new bushings, new ball joints and are powder-coated and ready to install. You can usually find them for $120 for the pair. I don't think you can buy the balljoints and bushings for that amount.
