Any problems with unvented solid wheels? #1828174
05/17/15 12:38 AM
05/17/15 12:38 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
Hi. Do you think there would be any problems brakes or anything getting hot if I used unvented solid wheels? Car is street driven, beat up 383 RR with original drum brakes.
I want to try something and was looking at Wheel Vintiques smoothie wheel. It looks like an EOM wheel for a vintage pickup, and street rod guys use them, I think. Thanks.
68 Roadrunner. 383 4-spd. Beat up.
Re: Any problems with unvented solid wheels? [Re: Mebsuta] #1828220
05/17/15 01:37 AM
05/17/15 01:37 AM
I would say you wont have a problem. If so I saw a pic where a guy added a 90 deg ear fabbed fitting to the backing plate(s) to catch air
Re: Any problems with unvented solid wheels? [Re: Mebsuta] #1828490
05/17/15 01:53 PM
05/17/15 01:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The factories did it for years an many different makes and models. If you're talking road course use then that would be different twocents
Re: Any problems with unvented solid wheels? [Re: Mebsuta] #1828802
05/17/15 10:12 PM
05/17/15 10:12 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
only problem is finding the lug studs when you are trying to install them on the car
Re: Any problems with unvented solid wheels? [Re: upnover] #1829380
05/18/15 06:35 PM
05/18/15 06:35 PM
Frederick , MD
GibW340 Offline
GibW340  Offline
Frederick , MD
I blame them for trashing the rotors on my 89 Ram van in less than 15000 miles- they over heated pulling our pop up down out of the Smokey Mts......
