what to look for? #1827874
05/16/15 04:28 PM
05/16/15 04:28 PM
usa
jd451 Offline OP
jd451  Offline OP
usa
I bought a 75 dodge van, has a 318, overall it runs good, my problem is trying to set the timing. Can't read the mark on the balancer, I marked it so I could see it, i'm on #1 wire. It pings under load, and has a low speed surgeons also. I lowered the timing by ear, then it feels sluggish. I did notice when the vacuum advance is hooked up the engine acts unstable and doesn't increase RPM. This engine is basically stock, just headers, LD4B intake, eddy 600 carb, any thoughts would be appreciated.
Re: what to look for? [Re: jd451] #1827895
05/16/15 04:51 PM
05/16/15 04:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Vacuum hose to distributor disconnected while checking timing?
Re: what to look for? [Re: DaytonaTurbo] #1827907
05/16/15 05:17 PM
05/16/15 05:17 PM
usa
jd451 Offline OP
jd451  Offline OP
usa
I've done that.
Re: what to look for? [Re: jd451] #1827911
05/16/15 05:22 PM
05/16/15 05:22 PM
usa
jd451 Offline OP
jd451  Offline OP
usa
Let me add, I am noticing that the T light starts flashing fast like a strobe. But will act normal also, does it on every cylinder. This is a good T light, works fine on my other car
Re: what to look for? [Re: jd451] #1827923
05/16/15 05:42 PM
05/16/15 05:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Have you checked the timing chain for stretch yet?
Re: what to look for? [Re: jd451] #1827936
05/16/15 05:55 PM
05/16/15 05:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the inside of the distributor cap for arc marks and look at the center of the rotor for burns.
Re: what to look for? [Re: jd451] #1828906
05/18/15 12:38 AM
05/18/15 12:38 AM
Manitoba, Canada
Manitoba, Canada
Have you tried advancing or retarding timing a lot? Eventually the mark should be showing up on the damper.
Re: what to look for? [Re: DaytonaTurbo] #1828941
05/18/15 01:44 AM
05/18/15 01:44 AM
first we gotta find/fix the light hookup that is making it act up cuz we ain't gonna get a true reading till we do, then basic stuff: initial (on ported)/total/what RPM the total maxes out at/vac can holds vacuum. this'll get us started. what idle RPM?. true TDC on dampener/rotor phasing but easy stuff first. always pinged or just started (any changes preceding it doing that? you can eyeball the dist springs (broken or good & 1 heavy/1 light is OE). holler when you can
Re: what to look for? [Re: RapidRobert] #1829060
05/18/15 11:51 AM
05/18/15 11:51 AM
md
mopars4ever Offline
mopars4ever  Offline
md
make sure the vacuum advance hose is hooked up to the correct port on the carb.
