wire pin locks #1827202
05/15/15 12:40 PM
05/15/15 12:40 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
They suck to install and remove. Thanks for letting me vent.
Re: wire pin locks [Re: Hot 340] #1827207
05/15/15 12:43 PM
05/15/15 12:43 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Spirolox or circular wire style?
The circular wire are a lot easier when they have a tang to grab onto with your needle nose pliers during the install. But I think some companies don't use the tang out of fear they'll break off later and mess up the engine.
Re: wire pin locks [Re: PorkyPig] #1827219
05/15/15 01:05 PM
05/15/15 01:05 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Wire circular locks with no tang. Spirolox are old friends.
Re: wire pin locks [Re: Hot 340] #1827286
05/15/15 03:21 PM
05/15/15 03:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's all in the way you hold your tongue. laugh2
Re: wire pin locks [Re: John_Kunkel] #1827338
05/15/15 04:06 PM
05/15/15 04:06 PM
dogdays Offline
dogdays  Offline
If you're a newbie like me, Spirolocks are a big PITA to remove. You need the right tool or else risk messing up the piston skirt, among other things.
The round wire with the beveled pin end is much easier to deal with in my estimation, although those doggone wire rings occasionally will fly across the room.
Anyone remember the double Waldes Tru-Arcs? Using a snap ring pliers, install two each side, making sure the sharp edges face away from each other.
R.
Re: wire pin locks [Re: dogdays] #1827372
05/15/15 05:11 PM
05/15/15 05:11 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
this guy makes it look easy !
https://www.youtube.com/watch?v=3kdhGBCpuxM
Re: wire pin locks [Re: Hot 340] #1827402
05/15/15 06:11 PM
05/15/15 06:11 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Spiro-locks are just a matter of learning what it takes to get them in and out. I can do it quickly, but still hate them. My number one choice for locks is pin buttons
Monte
Re: wire pin locks [Re: Hot 340] #1827410
05/15/15 06:20 PM
05/15/15 06:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I love them and just had the opportunity to install double (32) in my JE pistons for a small block I am putting together.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: wire pin locks [Re: pittsburghracer] #1827413
05/15/15 06:33 PM
05/15/15 06:33 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Spiroloxs are a breeze. These wire locks with no tang are not.
Re: wire pin locks [Re: Hot 340] #1827503
05/15/15 09:12 PM
05/15/15 09:12 PM
PA.
"Little"John
"Little"John
PA.
I'll tell you what works well for me on the ones with or without tangs. I lay the rod and piston on a nice towel on my workbench and take a sharp pointed pick scribe in one hand and a very small flat bladed electronics screwdriver in my other hand. Find the end and partially move it out some while applying pressure with the screwdriver to hold it in place. This allows you to get a better bite with the pick and get it out of the groove. Its all down-hill from there. With good lighting, proper height chair to be comfortable, and my bifocals its a cake walk.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: wire pin locks [Re: pittsburghracer] #1827515
05/15/15 09:47 PM
05/15/15 09:47 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
i have chased a couple wire clips around the shop until i made a square u shaped copper wire quard 4" x "4 and insert one leg into the pin, so far its saved the wire from leaving the work area. your results may vary!
Re: wire pin locks [Re: Hot 340] #1827530
05/15/15 10:08 PM
05/15/15 10:08 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i like cake
Re: wire pin locks [Re: Monte_Smith] #1828092
05/16/15 10:39 PM
05/16/15 10:39 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Monte
I'm thinking of these also, what do you think of using in a street engine, very limited use?
Re: wire pin locks [Re: cudaman1969] #1828638
05/17/15 05:36 PM
05/17/15 05:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Done correctly they are all easy to install.The wire clip is the easiest,just put one end in the groove and with a small blunt ended screwdriver or pick follow the clip at the point outside the bore pushing it in a little at a time.Usually when you get it over half way in you can push on the remaining part and it snaps right in place. up
Re: wire pin locks [Re: B G Racing] #1828689
05/17/15 07:30 PM
05/17/15 07:30 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Made this tool in my lathe, works great ......
Re: wire pin locks [Re: Hot 340] #1828896
05/18/15 12:23 AM
05/18/15 12:23 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I just learned how to install spiro locks. Took forever to do the first one but once I figured it out they take mere seconds.
Popping them out is no big deal if the piston has the little relief to get a screwdriver blade under the spring. You gotta force it a little at first but then it comes right out.
When I was learning how to install them on the first piston, it seemed like the pin bore around the lock groove was getting a little boogered up. It's in now but I am trying to not to think about that. tsk
'71 Duster
'72 Challenger
'17 Ram 1500
