bad vibrations #182752
01/03/09 05:19 PM
01/03/09 05:19 PM
kentucky
roadrunner7020 Offline OP
kentucky
So i recently installed the new 440 and i took it out but when i bring the car to around 1800 - 2000 i get a horrible driveline vibration and it smooths a little more as the rpms climb. The motor ran fine before in the gtx it was in however the only thing i have changed is the stall/convertor. I have checked the harrmonic balancer as that is what it felt like however it is good. Anyone had this problem before any suggestions. Also i have checked the flexplate to flywhell/convertor bolts all are tight. Thanks in advance!
Re: bad vibrations [Re: roadrunner7020] #182753
01/03/09 06:04 PM
01/03/09 06:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wrong converter? You need to see if has weights on it or not. Then figure ouy if your engine is internally or exturnally balanced.
Re: bad vibrations [Re: roadrunner7020] #182754
01/03/09 06:13 PM
01/03/09 06:13 PM
kentucky
kentucky
motor is and internally balanced 440 70 model all new with around 1350 miles on it
Re: bad vibrations [Re: roadrunner7020] #182755
01/03/09 07:57 PM
01/03/09 07:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Does the converter have weights on it?
Re: bad vibrations [Re: stumpy] #182756
01/03/09 08:05 PM
01/03/09 08:05 PM
kentucky
kentucky
just checked yes the convertor has weights on it
Re: bad vibrations [Re: roadrunner7020] #182757
01/03/09 08:11 PM
01/03/09 08:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
take the weight off it. weights are for externally balance engines. IE: 360, 440 cast crank engines, most 400's, and late 340's. Your engine should not have a weighted converter.
Re: bad vibrations [Re: MoparforLife] #182758
01/03/09 08:12 PM
01/03/09 08:12 PM
kentucky
kentucky
thanks for the help i will remove them tommorow and post an update
Re: bad vibrations [Re: roadrunner7020] #182759
01/11/09 08:27 PM
01/11/09 08:27 PM
kentucky
kentucky
Vibration is gone sorry for the late reply. Thanks again moparts members!!!
Re: bad vibrations [Re: roadrunner7020] #182760
01/11/09 08:41 PM
01/11/09 08:41 PM
Upper Midwest
Upper Midwest
Well what was it??
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: bad vibrations [Re: MoparforLife] #182761
01/11/09 09:08 PM
01/11/09 09:08 PM
kentucky
kentucky
weighted torque convertor took the weights of vibration free
Re: bad vibrations [Re: roadrunner7020] #182762
01/11/09 10:01 PM
01/11/09 10:01 PM
Upper Midwest
Upper Midwest
Glad you found it and it wasn't too hard to cure.
