numbers on a 360 magnum block #182651
01/03/09 03:53 PM
01/03/09 03:53 PM
Anonymous OP
Anonymous OP
i was told that there was a certan year magnum block that wasnt any good can someone tell me the numbers
Re: numbers on a 360 magnum block #182652
01/03/09 08:46 PM
01/03/09 08:46 PM
Anonymous OP
Anonymous OP
come on fellas im lookn for some help here i need to know what block not to buy for my car
Re: numbers on a 360 magnum block #182653
01/03/09 09:55 PM
01/03/09 09:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ok..who did u here it from?
and what is his/her experience with 360 magnum engines?
Tony
70 AARCuda Vitamin C
Re: numbers on a 360 magnum block [Re: 70AARcuda] #182654
01/03/09 10:09 PM
01/03/09 10:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There isn't a "bad" 360 magmum block. Some one is misleading you.
Re: numbers on a 360 magnum block #182655
01/03/09 10:21 PM
01/03/09 10:21 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Someone probably got confused and told you there is a bad 5.9 block, which there is (some people say a certain casting # cracks) but its the diesel . Never heard anything bad about the 5.9 gasser except on mileage
Re: numbers on a 360 magnum block [Re: jerseybud] #182656
01/03/09 11:03 PM
01/03/09 11:03 PM
Anonymous OP
Anonymous OP
the guy at the machine shop told me about it he said he wasnt shure but for me to check didnt wana put alot of money in a motor for it to come apart because of that
Re: numbers on a 360 magnum block #182657
01/03/09 11:11 PM
01/03/09 11:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
find another machine shop........
Tony
Re: numbers on a 360 magnum block [Re: 70AARcuda] #182658
01/04/09 01:17 AM
01/04/09 01:17 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They all use the same blocks witch structurally they are the same as the older ones. The main differance is they have a boss to mount a crank sensor and the oil passage to the heads is not drilled out.
