Re: '81 Dodge D150 Gas Miser, which OD Trans was used?
[Re: D_C]
#1825907
05/13/15 05:45 PM
05/13/15 05:45 PM
Posts: 15,487 Florida
scratchnfotraction
would be the alum case 833OD 4 speed that used a truck shifter/mount with long tail shaft.
225 /6 833OD 4 speed 8 1/4 rear = 10 bolt with a 2.76 gear turning a 195/75/15
FYI.. the B-body 833 4 speed with a pistol grip shifter is a bolt in for the trucks also. /6 work great with a regular 4 speed as well.
[Re: D_C]
#1825909
05/13/15 05:48 PM
05/13/15 05:48 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
The good one. A833od and if it's all in one piece will have the good shifter too. And, even better yet, it is behind a /6 so you know it couldn't have been under too much stress.
Mo' Farts
Moderated by "tbagger".
[Re: D_C]
#1825917
05/13/15 06:01 PM
05/13/15 06:01 PM
Posts: 6,017 Salem
Grizzly
Salem
If you really want to get creative, gm used the exact same transmission behind some of their 4wd trucks. The only ones I've seen were behind 6.2 diesels but another source for you may be from some gasoline trucks. At any rate............you will have something that comes with a transfer case, and with a bit of research on your part, should be able to bolt to a Dodge bellhousing somehow (input bearing size, input shaft length). Get my drift? Blunder Motors transfer case will be the weak link, not the A833 trans.
Mo' Farts
[Re: D_C]
#1825935
05/13/15 06:25 PM
05/13/15 06:25 PM
Posts: 6,017 Salem
Grizzly
Salem
Get it, for sure. Grab everything: the pedals, linkage, shifter, bellhousing, all of it. Took years for me to find one in a D100 with the 318. The 318 bellhousing is pure gold to me (needed for stroker small blocks) and since there is nothing but negative things said on here about this trans, I had to find out for myself. So I got one, and can't stop driving it. Ignore the negative on here about the a833od: this thing is a hoot to drive and I'm going this route on all my hotrods instead of the $5000.00 alternatives. Hope that answers your "valuable" question.
Mo' Farts
[Re: Grizzly]
#1826480
05/14/15 10:36 AM
05/14/15 10:36 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Blunder Motors transfer case will be the weak link, not the A833 trans. BM or GM used the same transfer cases as Dodge. They were New Process cases.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: D_C]
#1826500
05/14/15 11:42 AM
05/14/15 11:42 AM
scratchnfotraction
Thanks. I told a friend about it. He grabbed the Shifter (a factory Hurst unit) and the Z-Bar. Not sure I can afford the time or money to pull the Trans, bell housing, etc. though it might well be worth it for resale. the trans is good to save if nothing other than to sell it to brewers as a core. /6 bell maybe not so much. your buddy got the gold nugget. hope he grabs the mount & rods.
[Re: D_C]
#1826504
05/14/15 11:54 AM
05/14/15 11:54 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I have two and half of them, plus a V8 bell and a /6 bell and the shifters, linkage, clutch parts etc from a truck sitting in my garage awaiting transplant into the Cuda. Whole mess of stuff I bought off a seller on Ebay for like $200 for everything.
Not really valuable as most think it's weak, with too wide gear rations and first too deep. But if you look at what's coming out today, deeper first, weaker trans, etc.
[Re: scratchnfotraction]
#1826774
05/14/15 06:42 PM
05/14/15 06:42 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
Thanks. I told a friend about it. He grabbed the Shifter (a factory Hurst unit) and the Z-Bar. Not sure I can afford the time or money to pull the Trans, bell housing, etc. though it might well be worth it for resale. the trans is good to save if nothing other than to sell it to brewers as a core. /6 bell maybe not so much. your buddy got the gold nugget. hope he grabs the mount & rods. I grabbed the shifter assembly, handle, rods, levers, mounting pad, etc. I also grabbed the zbar in hopes of using it on my 71, even though the 71 is a 318 and the truck the zbar came from was a slant six. Gonna use the shifter on a 3 speed
[Re: D_C]
#1842999
06/06/15 06:36 PM
06/06/15 06:36 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I would grab the reforcement plate off the floor board for the shifter....I'm getting ready to do this swap in my 86 RC....not a 4wd though.....Dr.Diff was the first person that told me a about the Cheby's....even showed me a picture of it on the floor.
I wouldn't mind finding one on of these cheby 833 my self.
Moparlee
[Re: D_C]
#1843000
06/06/15 06:37 PM
06/06/15 06:37 PM
Robbins
Joplin, MO USA
I would grab the reforcement plate off the floor board for the z bar....I'm getting ready to do this swap in my 86 RC....not a 4wd though.....Dr.Diff was the first person that told me a about the Cheby's....even showed me a picture of it on the floor.
Moparlee
