318 crank in a 360 block #182590
01/03/09 02:34 PM
01/03/09 02:34 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I think I remember reading somewhere that they make main bearings that make this possible. Will someone let me know if this is true or if I was dreaming.
Re: 318 crank in a 360 block [Re: alpha727] #182591
01/03/09 02:40 PM
01/03/09 02:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, you can buy the bearing spacers to make it work. Mancini should have them.
Re: 318 crank in a 360 block [Re: Neil] #182592
01/03/09 02:52 PM
01/03/09 02:52 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Scratch that idea I could buy a 4" crank for cheaper than that.
Re: 318 crank in a 360 block [Re: alpha727] #182593
01/03/09 02:57 PM
01/03/09 02:57 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I think I'll stick with my 318 idea and put my money in the heads. Thanks for the help.
