How many more MPG with EFI?
#1825416
05/13/15 01:37 AM
05/13/15 01:37 AM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
How many more MPG can I expect from EFI on a 73 Charger? What does a typical EFI system go for?
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
Re: How many more MPG with EFI?
[Re: xyxxjx]
#1825418
05/13/15 01:42 AM
05/13/15 01:42 AM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
ideally if you have a well tuned carb maybe 1-2mpg more. but in reality most carbs people pull out of the box and drop onto their engines, maybe swapping some jets, etc, but never get the tune really good with adjusting air bleeds etc. so in reality if your good at tuning the efi I wouldn't be surprised at 4-5 mpg increase or even more, depending on how you drive your car, how large the engine is, how good the engine is built etc. efi systems can get from 4-500 dollars build it yourself up to 3000+ for an all inclusive kit and some dyno tuning.
[Re: Jerry]
#1825442
05/13/15 02:22 AM
05/13/15 02:22 AM
Posts: 4,774 Star Idaho
67vertman
Star Idaho
It is going to be based on what type of EFI system you buy. A plug and play (self learning) system...maybe 2 - 4 MPG, more if you drive conservable. If you get a tunable EFI and are good at tuning or have someone write you a tune then maybe 4-10 MPG. A lot will also depended on the motor you are running.
My system is a FAST ECU and F&B 6pac, 500 hp 440....I am averaging 8-10......but I have a difficult time keeping my foot of the Load Pedal. I could have it retuned and if I only drove on the center throttle body I probably would be in the 15 range......but what fun would that be.
My Monster are real!
Living within your means makes life pretty easy.
[Re: xyxxjx]
#1825449
05/13/15 02:34 AM
05/13/15 02:34 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
On the W350, I can tell you TBI injection and an overdrive is good for about 6-7mpg on a 360 built for torque. Built the motor before, and with both the Thermobog and a Demon carb it was getting about 10-11. Typical of a truck with 4.10 gears of that era. Plenty of power, it would light all 4 tires up even at this altitude. After all the changes and some tuning it will pull 17mpg over 2 mountain passes gaining 6800' in altitude at 65mph. That's about as fast as she will go... I would say each one is worth 3mpg, but I don't have a baseline with only one change since they were both done at one time.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: xyxxjx]
#1825582
05/13/15 11:23 AM
05/13/15 11:23 AM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Going to a self tuning EFI system is no guarantee that your performance or your mileage will improve. There are a good number of threads on this subject and there are plenty of users that are not happy and some have even removed the EFI.
The difference in economy between your carb and EFI is totally dependent on the quality of the tune in the carb compared to the abilities of the EFI. And again, there is no guarantee that there would be any improvement with EFI over your carb.
Are there any complete EFI systems out there for less than $2,000 including the fuel pump and it's parts? And that is not including labor. Plus, the EFI can only do so much without tuning the ignition. But that is either a more expensive and complicated EFI system or more time and money to dial it in.
In a lot of cases it would seem to make more sense to get a competent carb tuner to select the correct carb for the application and tune the carb and ignition on a dyno for optimum economy. That would cost half the amount of the EFI and except for the starting procedure could well out perform many self tuning EFIs.
Master, again and still
[Re: 360view]
#1825613
05/13/15 11:55 AM
05/13/15 11:55 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
"Note that every auto driving below 80% throttle got better MPG, less crude oil was imported, and less CO2 emitted."
With all the research and development dollars spent on those platform specific systems and all they got was 2 MPG? So just how much improvement should you then expect a universal self tuning system to deliver?
Remember too, that they optimized the ignition for the application. I keep bringing that up because most self tuning EFIs do not control the ignition. And we all know that any fuel delivery system is dependent on the ignition to work at it's full potential.
[Re: xyxxjx]
#1825775
05/13/15 02:38 PM
05/13/15 02:38 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You will not get much more MPG than a freshly adjusted carb. That said, the continuous adjusting of the EFI will keep your engine in tune for a whole lot longer than your carb will so long term MPG will increase. I love carbs and the challenge of getting them tuned for best performance. But the variation of gasoline formulas, the temperature variations of the seasons and just time in general mess up the settings. If you have an O2 sensor hooked up, you can watch it vary from day to day and gas tank to gas tank fill. With closed loop EFI that optimum tune lasts for a lot longer. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: xyxxjx]
#1825788
05/13/15 02:58 PM
05/13/15 02:58 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Original poster is listed as living in Los Angeles. I don't know what areas he drives in, but the stop and go city driving here gives you much different MPG than those living even in the suburbs of LA let alone less dense city or less dense suburb type driving.
I wonder if the benefits of EFI would be less in heavy metropolitan driving?
I have a work vehicle that I drive in metro LA and get 3-4 MPG difference than the same vehicles in Rural-City mix in Central CA and Riverside (city but much less dense). -Those MPG calcs are made filling the tank and recording the exact milage accurately in a log book.
[Re: xyxxjx]
#1825839
05/13/15 04:14 PM
05/13/15 04:14 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
A carb can not cut off the fuel during coasting like EFI can. It can not mix the fuel at lower speeds like EFI can unless you compromise higher speed flow. There are a lot more compromises with a carb.
[Re: DaveRS23]
#1825961
05/13/15 07:32 PM
05/13/15 07:32 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Remember too, that they optimized the ignition for the application. I keep bringing that up because most self tuning EFIs do not control the ignition. And we all know that any fuel delivery system is dependent on the ignition to work at it's full potential. Remember, too, that a carb has to be retuned for every weather change then tuned again for differences in altitude. EFI is not a magic wand but it will generally improve the driving experience as well as fuel efficiency.
[Re: xyxxjx]
#1825984
05/13/15 08:01 PM
05/13/15 08:01 PM
xyxxjx
Los Angeles CA
My current carburetor is a Carter AFB 4 barrel. I don't know how well it can be tuned. Yes, I'm in los Angeles, so lots of stop and go traffic. I know this will depend on a lot of things, but is there a rule of thumb as to how many miles you have to put on the car before an efi system has paid for itself?
[Re: xyxxjx]
#1826000
05/13/15 08:09 PM
05/13/15 08:09 PM
xyxxjx
Los Angeles CA
We don't have such wild temperature swings here in L.A. so I'm guessing that 90% of the time I'll be driving the temperature will be in the 70s or 80s.
[Re: xyxxjx]
#1826101
05/13/15 09:23 PM
05/13/15 09:23 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
All this support for what EFI "is capable of". But in the real world after 60+ years of carbs and most guys don't even know how to size a power valve and then you're talking about dry intakes and sizing injectors. Get a grip!
A properly set-up and tuned EFI engine management system is the way to go. But is out of the reach (in more that one way) of most muscle car hobbyists.
The OP is interested in a plug and play self tuning system. For half the money, he can have a proper carb tuned and his ignition dialed in to his combo. Which would likely outperform an economy self tuning EFI kit. So let's compare apples to apples here.
And no one has quoted real world prices on a complete EFI system, have they? One with all the pieces needed for a real install. And then it is very possible that it will be a turd. Read the posts on here about these self tuning systems. There are more unhappy owners than happy.
EFI is probably the future. But here and now, they are expensive, changing constantly, and not quite ready for prime time. When they get their act together, I will have one on all my cars. But not today. Not yet, they're just not ready.
[Re: xyxxjx]
#1826199
05/13/15 11:14 PM
05/13/15 11:14 PM
Posts: 4,740 Florida
BDW
Let's be optimistic, given the following you would break even after 3yrs.
EFI cost: $2400 Yearly miles: 6000 Initial MPG: 10 EFI MPG: 15 (5 MPG improvement) Gas cost: $4 per gallon
Gas cost carb: (6000/10) x 4 = $2400 Gas cost EFI: (6000/15) x 4 = $1600
So you would save $800 per year.
Cut your miles per year in 1/2 (3000), then its 6yrs Cut improvement in 1/2 (2.5 mpg), then its 12yrs
Not a good return on investment
[Re: DaveRS23]
#1826334
05/14/15 12:35 AM
05/14/15 12:35 AM
Posts: 3,443 Dandridge TN
Dabee
Dandridge TN
Wow, lots of discussion, or maybe I should say speculation posted, but no one has really answered the posters question. Has any of the posters actually bought and installed a self learning EFI on their muscle car or are they going on hear say and not actual experience. I have a 512 stroker in my street car. I was running a Quick Fuel 1050 on it with a MSD billet dizzy with only mechanical advance. The 1050 was dialed in using an O2 gauge. The car ran great, but as stated buy several posters, the tune went away with temperature swings. The 512 was getting around 9 to 10 mph with the 1050. Okay ibises for a well tuned 512. But let's face it if you build a stroker motor your really not very concerned with economy, which I am not.
Two months ago I got tired of chasing the tune and bought a Fast 2.0 EFI and installed it on the 512. Total cost was in the $2850 range. The Fast 2.0 is a throttle body EFI and it controls the ignition, as does the MSD Atomic EFI. MPG is now 13 MPG. Thats a Hugh improvement. My personal thoughts are the majority of the mileage increase is due to better ignition control. I went from 36 degrees total, all in at 2200 rpm to a full ignition curve that incorporates mechanical and vacuum advance. Timing at cruse is now set at 39 degrees and I'm considering increasing it to 42 degrees. I'm betting the mileage increases with the timing increase. The engine is happier and so am I. My advice to the original poster is this. If you can afford the cost of the EFI and your car is mostly driven on the street, get the EFI. I hope this answered your question.
