Had someone combing through my Engine compartment #182500
01/03/09 01:29 PM
01/03/09 01:29 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Took my Dart out to our weekly cruise night for the first time.
Had a Chevy guy going over some stuff in the engine compartment and making comments,I would like to know everyones take on the comments.
We are emissions exempt here and the engine is a 1977 225 in a 72 Dart.
I have the EGR port at the manifold plugged and the EGR valve reversed,thus blocking it off. This guy told me I should run the EGR as it would make the engine perform better.
Then he noticed the steel line coming up from under the firewall that usesd to run to the Charcoal canister,which I took off and threw away.
He says I should put it back on so the car will run better with it.
Like I said we are emissions exempt,so I took all uneccessary components and tossed them.
What do you all think of this Chevy Guys comments?Is he right or should I not even bother with the emissions stuff I took off?
Re: Had someone combing through my Engine compartment [Re: SPWC] #182501
01/03/09 01:32 PM
01/03/09 01:32 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
My guess is that his definition of "run better" and yours are diametrically opposed.
Did he have tree marks all over his body from too much embracing?
Re: Had someone combing through my Engine compartment [Re: Pacnorthcuda] #182502
01/03/09 01:40 PM
01/03/09 01:40 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Your car is a 1972 and therefore does not have to have any of the equipment since you're not in California. Your engine will make more power and have better driveablity without the EGR and charcoal canister.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Had someone combing through my Engine compartment [Re: goldduster318] #182503
01/03/09 01:52 PM
01/03/09 01:52 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
its still illegal to remove emissions controls.
Re: Had someone combing through my Engine compartment [Re: 05dakota] #182504
01/03/09 02:07 PM
01/03/09 02:07 PM
SPWC Offline OP
SPWC  Offline OP
Even if the engine thats equipped with emissions is installed in a Bodystyle and year of a vehicle that wasnt?
For example taking a 1978 Smog 318 and installing it in a 67 Satelitte?
Re: Had someone combing through my Engine compartment [Re: 05dakota] #182505
01/03/09 03:07 PM
01/03/09 03:07 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
And it's illigal to remove the tags from your mattress.
Chevy guy was most likely a dealer tech that knows little more than what he was taught by Chevy for newer cars.
Re: Had someone combing through my Engine compartment [Re: SPWC] #182506
01/03/09 03:08 PM
01/03/09 03:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Smog stuff goes by body year not engine. If you put an older non smog engine in a later smog car you need to install smog equipment. If you go the other way you can remove the smog stuff.
Re: Had someone combing through my Engine compartment [Re: StealthWedge67] #182507
01/03/09 03:17 PM
01/03/09 03:17 PM
CHRGR69 Offline
CHRGR69  Offline
And it's illegal to remove the tags from your mattress.
It is??? Oh S---!
Grandma always said I had "hands of gold"!
Re: Had someone combing through my Engine compartment [Re: Pacnorthcuda] #182508
01/03/09 03:58 PM
01/03/09 03:58 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
That is priceless! Couldn't of said it better.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Had someone combing through my Engine compartment [Re: SPWC] #182509
01/03/09 05:10 PM
01/03/09 05:10 PM
which I took off and threw away. What do you all think of this Chevy Guys comments?
Throw the chebby guy out of your garage, problem solved
Re: Had someone combing through my Engine compartment [Re: SPWC] #182510
01/03/09 05:15 PM
01/03/09 05:15 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Tell the Chivie guy to go pound sand!!!!
Re: Had someone combing through my Engine compartment [Re: RapidRobert] #182511
01/03/09 05:19 PM
01/03/09 05:19 PM
MO
cdp Offline
cdp  Offline
MO
Or, buy the GM's guys correct emissions vehicle and give your Mopar away. You saved the enviroment and made the GM guy happy.
Our goal in life is to make everyone else happy...right?
Re: Had someone combing through my Engine compartment [Re: SPWC] #182512
01/03/09 06:59 PM
01/03/09 06:59 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Well I know I'll get blasted for this, but I saw a program a while back where they were discussing just this issue, whether to dump the emmissions stuff. The guy on the show was real informative and gave numerous straight forward reasons why it was better to leave it on. I honestly cant remember any of them, I just recall turning off the program thinking my opinion had changed as I thought that dumping it was a no brainer beforehand. Maybe some more knowledgable experts here can sort of discuss this more specifically.
Re: Had someone combing through my Engine compartment [Re: moparmojo] #182513
01/03/09 07:06 PM
01/03/09 07:06 PM
Puyallup, WA
Puyallup, WA
Consider this your first blast.... carefully take the hook out of your cheek.
just messin wicha'
Re: Had someone combing through my Engine compartment [Re: moparmojo] #182514
01/03/09 07:07 PM
01/03/09 07:07 PM
Some emissions equipment does not have a downside other than cluttering up the bay. Things like
The charcoal canister, Air aspirator tubes/valves, and PCVs.
Others rob power like smog pumps
Others prevent max power from being produced like EGR valves, Catalytic converters.
The above is only some of the old school stuff, on a 'modern car' (like anything post
85 ) the paraphenalia can be mindboggling and removing it difficult.
Re: Had someone combing through my Engine compartment [Re: SPWC] #182515
01/03/09 07:11 PM
01/03/09 07:11 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
The only way anyone is going to make comments like that about my stuff is if they have cash in hand and are buying. Otherwise, take a hike.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Had someone combing through my Engine compartment [Re: Pacnorthcuda] #182516
01/03/09 08:29 PM
01/03/09 08:29 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I call BS on that one, an EGR cools cylinder temp therefore making an engine run more cleaner and more efficient. Producing more power. As far as a charcoal cannister and the smog pump, they pull an engine down. Ditch them if ya can.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Had someone combing through my Engine compartment [Re: 70dart360] #182517
01/03/09 08:34 PM
01/03/09 08:34 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
If EGR's made power wouldn't most guys run one? It actually does the opposite, hot exhaust gas entering the intake heats up the incoming charge and basically pollutes the mixture. Even most oem egr setups shut off the egr at wot/under high load because it robs power or at least can cause pinging/detonation.
Re: Had someone combing through my Engine compartment [Re: SPWC] #182518
01/03/09 08:40 PM
01/03/09 08:40 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I see Chevy guy's lips move, but I've trained myself not to hear
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Had someone combing through my Engine compartment [Re: SPWC] #182519
01/03/09 08:56 PM
01/03/09 08:56 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Mustve been Al Gore checking your care out. Funny I thought he drove a Hyundai.
Just remove the rest of the evidence of the charcoal canister and get a EGR block off plate.
Then tell the Chevy guy that the car ran worse when you put those parts back on, and you found out it wasnt supposed to have them because its a 1972.
