Heater Hose hook up.. 440 engine.. #1824708
05/12/15 01:10 AM
05/12/15 01:10 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Hooking up my heater hoses, which nipple is the pressure side, and which one is the return on a 440 engine.. I have a new heater core, and never plan on using the heater so I want to keep AF out of the core... Thanks for your info..
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1824720
05/12/15 01:22 AM
05/12/15 01:22 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/6661638/site_id/1#import
But if you are not going to use the heater, why not just block off the fittings in the first place perhaps ?
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1824721
05/12/15 01:24 AM
05/12/15 01:24 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Been too many years for me to remember which is which. A FSM has a flow diagram. If you dont have one, join 69roadrunner.net and the entire book is online there.
I want my fair share
Re: Heater Hose hook up.. 440 engine.. [Re: OzHemi] #1824735
05/12/15 01:58 AM
05/12/15 01:58 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I did,, but it looks sloppy..
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1824766
05/12/15 03:28 AM
05/12/15 03:28 AM
hot coolant exits a BB block from the top/upper hole(s) (1) on each side & turns in to the center to the stat so the rear (upper) heater hose nipple on the pass side right there that taps down into that passage is the hot coolant "out" to the heater "inlet"
Re: Heater Hose hook up.. 440 engine.. [Re: RapidRobert] #1824782
05/12/15 06:20 AM
05/12/15 06:20 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
70 FSM
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1824808
05/12/15 09:46 AM
05/12/15 09:46 AM
robertop Offline
robertop  Offline
Not to hijack this thread, but is this the same setup for a 69 Hemi engine? Thanks, guys.
Re: Heater Hose hook up.. 440 engine.. [Re: thehemikid] #1824817
05/12/15 10:23 AM
05/12/15 10:23 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Thanks for the info..
Re: Heater Hose hook up.. 440 engine.. [Re: robertop] #1824867
05/12/15 12:14 PM
05/12/15 12:14 PM
Not a problem on the hijack, the OP has had his Q ans & your post ain't interfering with that in any way & we're here to help and be helped in any way and as much as possible. I'm 99% sure the Hemi would be the same cuz it has the same WP so it'd have the same block hole configuration (upper/lower on each side on the front of the block)
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1824873
05/12/15 12:23 PM
05/12/15 12:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If 70 and later you can't go wrong !! work
Re: Heater Hose hook up.. 440 engine.. [Re: JohnH] #1825259
05/12/15 10:30 PM
05/12/15 10:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Simple, the nipple closest to the water outlet is the supply, that leaves the other as the return.
Don't be the exception.
