Jeep oil over fill #1824503
05/11/15 09:21 PM
05/11/15 09:21 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
2001 Jeep Cherokee 4.0 oil over fill problems?
A friend carried her Jeep to a garage for an oil change and it has not been running right since.Her bill lists 5 quarts of 5w40 and 1 quart of 10w40 (6 Quarts total). Will over filling create problems? Thanks!
Re: Jeep oil over fill [Re: 68GTS383] #1824533
05/11/15 09:38 PM
05/11/15 09:38 PM
places
79powerwagon Offline
places
Re: Jeep oil over fill [Re: 68GTS383] #1824534
05/11/15 09:39 PM
05/11/15 09:39 PM
places
places
I'd guess maybe the PCV valve was jarred lose, causing a vacuum leak? Maybe at the brake canister?
Re: Jeep oil over fill [Re: 79powerwagon] #1824567
05/11/15 10:20 PM
05/11/15 10:20 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
She says that the oil level is way up on the oil stick.Will too much oil affect the way the engine runs?
Re: Jeep oil over fill [Re: 68GTS383] #1824584
05/11/15 10:40 PM
05/11/15 10:40 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
WAAAY up it certainly would, but a just a quart over, no.
Why one odd quart?
And, hopefully it didn't end up 5 and 5 (quarts).
Since oil control has gotten so much better I don't do it, but back in the "good old days" when going on a trip I routinely added an extra quart before I left.
And with some of those beauties ... I remember a trip from Florida to Vermont... it took 35 quarts for a 1400 mile trip ... '70 Monte Carlo SS454.
It takes gasoline to interest me.
Re: Jeep oil over fill [Re: 68GTS383] #1826124
05/13/15 09:58 PM
05/13/15 09:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I run my inline 6 cylinder a quart over all the time, helps keep oil pressure when the jeep is on a steep hill...think rock crawling. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Jeep oil over fill [Re: astjp2] #1826632
05/14/15 03:20 PM
05/14/15 03:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine has always been fine with the stock oil level, unless leaning way way over on the passenger side.
But like mentioned above the 4.0 holds 6 quarts of oil.
68 Barracuda Formula S 340
Re: Jeep oil over fill [Re: 68GTS383] #1826925
05/14/15 10:26 PM
05/14/15 10:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You are all assuming the place that added 5 quarts of one grade of oil and 1 quart of a different grade actually drained out the old oil before adding the new "mix".
I'm pretty sure if there are 12 quarts of oil in the 4.0, its not going to run very well. Gene
