Engine Unexpectedly Shut Down #1824339
05/11/15 06:15 PM
05/11/15 06:15 PM
CraigRTSE OP
CraigRTSE OP
Sitting at a traffic light the other day, car had been running and idling fine, when all of the sudden the engine shut down.
It wasn't a prolonged shut down, like being fuel starved. It was more like an electrical problem similar to if I had just turned off the ignition. The car started right back up and no problems since.
The only other problem related to this was back in the Fall, but that time the car would crank over, but not start. Never found out exactly why it didn't. The last thing I did before it started was wiggle the bulkhead connectors. Wondering if what happened the other day was related.
During the car's restoration, everything was replaced new and has 13,000 miles since the resto.
Ever had your car just shut down like that? If so, any idea, aside from the bulkhead, that I should look for? And if it is the bulkhead, what section or wire(s) should I focus on?
Re: Engine Unexpectedly Shut Down [Re: ] #1824346
05/11/15 06:23 PM
05/11/15 06:23 PM
MD
p d'ro Offline
p d'ro  Offline
MD
I have, but it did not restart. Lucky you. Good luck with it. Sorry I can't be more help other than the obvious. Loose distributor wires, ignition switch, grounds...
Re: Engine Unexpectedly Shut Down [Re: ] #1824357
05/11/15 06:49 PM
05/11/15 06:49 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I had the crank over no start issue, it was the reluctor to pickup gap, was around .022 when it should be set at .008 with a brass feeler gauge.
Re: Engine Unexpectedly Shut Down [Re: ] #1824366
05/11/15 06:58 PM
05/11/15 06:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
With the car running, grab the ignition switch connector at the base of the steering column and wiggle them around. My car did this and it turned out to be that connector. Wiggling the connector around made the car die. All I had to do was "adjust" the terminals so they fit tightly together. If that test turns out OK, do the same thing with the bulkhead connectors.
Re: Engine Unexpectedly Shut Down [Re: ] #1824369
05/11/15 07:07 PM
05/11/15 07:07 PM
to keep a car running only the coil positive primary terminal (fed thru the ballast) & the blue/yellow main feed for the ECU (4 pin ECU/dummy 5th pin ECU) need to have fire, this'd be the blue wire circuit ign1 (run) terminal interface at the bulkhead. I ain't sayin ign (& In fact I think fuel,not starvation but percolation like from E10) but I wanted to ans your Q
Re: Engine Unexpectedly Shut Down [Re: ] #1824602
05/11/15 11:03 PM
05/11/15 11:03 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I had the same issue with my Dart. Turned out to be the bulkhead connector.
Re: Engine Unexpectedly Shut Down [Re: ] #1824700
05/12/15 12:58 AM
05/12/15 12:58 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
With the car running, wiggle the wires going to the ballast resistor & if it sparks & shuts down, this is the problem. I had this happen to my old '71 Charger R/T & messed around replacing things for 2 weeks before discovering it was the $3.00 ballast resistor.
Re: Engine Unexpectedly Shut Down [Re: Sunroofcuda] #1824717
05/12/15 01:19 AM
05/12/15 01:19 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Check the connections on the ammeter too, maybe they are not tight and you get intermittent power. I had to have mine towed home one night as I had no power to anything.
Re: Engine Unexpectedly Shut Down [Re: ] #1824885
05/12/15 12:33 PM
05/12/15 12:33 PM
CraigRTSE OP
CraigRTSE OP
Thanks guys! Will do all of the above and let you know when I find the culprit!
Re: Engine Unexpectedly Shut Down [Re: RapidRobert] #1824998
05/12/15 03:12 PM
05/12/15 03:12 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
[quote) In fact I think fuel,not starvation but percolation like from E10 [/quote
What I thought. My Bee was stalling while sitting at a light. Switched to 100% gas and problem went away. Now running FAST EFI and back on 10% ethanol.
