how to tell between silcone / regular brake fluid #1824107
05/11/15 01:06 PM
05/11/15 01:06 PM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
Is there a quick way to tell between the two?
I got my old car back after 17 years and can't remember which I had in it.
Also don't know if the two previous owners had switched to what ever?
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824113
05/11/15 01:19 PM
05/11/15 01:19 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Suck some out of the master cylinder and put in in a small clear jar. Add a few drops of water to it, if it's silicone the water will quickly seperate from the brake fluid. If it's dot 3 or dot 4 the water will be slowly absorbed into the fluid.
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824120
05/11/15 01:29 PM
05/11/15 01:29 PM
Sharpsburg Maryland
Sharpsburg Maryland
Thanks I thought it would be something like that
Re: how to tell between silcone / regular brake fluid [Re: mrrandyj] #1824132
05/11/15 01:43 PM
05/11/15 01:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That beats my idea of seeing if it bubbled up the paint, lol.
Don't be the exception.
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824146
05/11/15 01:58 PM
05/11/15 01:58 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
It is alleged that silicone fluid is suppose to have a purple tint to it. I have in our 300 B Chrysler and it is purple. However would not wager that this always holds true.
I have seen advertised somewhere a product of test strips that you can sample your fluid by dunking them into it and this will tell you what fluid you have. Not to be confused with the strips that tell you percentage of water in you dot 3 and 4 fluids.
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824150
05/11/15 02:01 PM
05/11/15 02:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Don't they smell different?
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824152
05/11/15 02:03 PM
05/11/15 02:03 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Do they taste different?
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824601
05/11/15 11:01 PM
05/11/15 11:01 PM
GA
roadrunninMark Offline
GA
Dot 5 is very purple. Another trick you can do is put the brake fluid in your car on something painted. If it eats the paint, it isn't DOT 5.
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824626
05/11/15 11:25 PM
05/11/15 11:25 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
Another idea would be to dip a rubber o ring into the fluid. If it swells up it would be DOT 3/4.
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824696
05/12/15 12:50 AM
05/12/15 12:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Water test is best. The silicone starts purple but its color can change with age.
Doug
Re: how to tell between silcone / regular brake fluid [Re: 440farmer] #1824792
05/12/15 08:00 AM
05/12/15 08:00 AM
Sharpsburg Maryland
Sharpsburg Maryland
Thanks everyone
I'll try them all just to see what works best
I'm at work now i'll try this evening.
