transmission interchange question...98 Ram
#1823591
05/10/15 07:25 PM
05/10/15 07:25 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
So I have a 98 Ram 2wd, with 360 , is there any reason that I couldn't put the tranny from my 98 with the 360 into an 01 with 318 engine? Is this a straight up swap or was anything changed by 01? I know in the old days the only concern would be the tork convertor. Thx, Ken.
Re: transmission interchange question...98 Ram
[Re: StrokerPost]
#1824257
05/11/15 04:08 PM
05/11/15 04:08 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's a straight physical swap but the interchange manual will advise "Control module might require programming to allow proper shifting."
[Re: StrokerPost]
#1824344
05/11/15 06:18 PM
05/11/15 06:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Just swap the temp sensor and pigtail in the valve body. If you don't it will not get LU or OD as the sensors are calibrated different as it will think it is extremly cold.
The converter is the same basic thing.
[Re: StrokerPost]
#1826050
05/13/15 08:48 PM
05/13/15 08:48 PM
Posts: 2,042 colorado
savoy64
colorado
on doing a dakota swap--same years--you have to know if the computer wiring plug to the tranny is white or black--the one i had had a black square plug...
