1977 Club Cab - Other Years.....??..... #1820808
05/07/15 01:58 AM
05/07/15 01:58 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
If I am in search of a solid or as close to a solid as possible, 1977 club cab shell, what other years will work...??
If anyone happens to have one as described....feel free to drop me a line.
E-mail - Challengers1970@aol.com
Thanks!!!
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1820866
05/07/15 08:22 AM
05/07/15 08:22 AM
places
79powerwagon Offline
places
The extended cabs and 4 door cabs for the 70's trucks really had no changes done to them, so they are all pretty much the same. I was surprised to notice that teh 1990 trucks still used the "older, round roof" cabs on the extended cabs, but the regular cabs used the "new, square roof design". I believe the it was 1982 thru their end that used the square roof on regular cabs...
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1820958
05/07/15 11:40 AM
05/07/15 11:40 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
As stated, the cabs are mostly the same if it's a club or crew cab. 1981 is when the redesign happened, and from that point forward, the regular cabs got a much flatter, more squared-off roof.
OIF V and OEF X veteran and proud of it!
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823053
05/09/15 11:35 PM
05/09/15 11:35 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The Club Cab was done after 82 but started up again in 91. Same cab.
Kevin
Re: 1977 Club Cab - Other Years.....??..... [Re: Twostick] #1823185
05/10/15 03:00 AM
05/10/15 03:00 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Kevin
so....you are saying that the Club Cab sheet metal, roundness of the roof and all are the same as the 70's era cab...??
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823227
05/10/15 09:08 AM
05/10/15 09:08 AM
places
places
Yes
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823239
05/10/15 09:38 AM
05/10/15 09:38 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Indeed.
Whenever I am online I am totally naked. (Under my clothes)
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823254
05/10/15 10:24 AM
05/10/15 10:24 AM
places
places
Not an important detail, but one worth mentioning- Dodge used a variety of different rear windows on the regular cabs. I don't know if that is true of the Clubs, and I certainly doubt it's a big deal. smile
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823570
05/10/15 06:22 PM
05/10/15 06:22 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
alright thanks!!! So...to replace the cab of my 1977 club cab truck, all I really have to do is find a 91, 92 or 93 club cab truck or shell and I am in business....??
1990 and back cabs will not work...?? Anyone have any idea why they started using the old cab design again for the 91 & up trucks...??
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823573
05/10/15 06:35 PM
05/10/15 06:35 PM
places
places
All 70's thru 90's club cabs will work, but check the mounting points to be sure. They never changed them because they had the tooling already, may as well use it! smile
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1823982
05/11/15 05:16 AM
05/11/15 05:16 AM
69HemiGTX Offline
69HemiGTX  Offline
The Club Cab was offered from 73-82 and again from 91-93. As said, check for any minor differences. I'm sure there are some based on the different interior trim they could be had with.
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1824361
05/11/15 06:50 PM
05/11/15 06:50 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Kentucky? A bit distant. There is a 1980 Club Cab at my local Pick A Part (Southern California) and the cab looks to be in good condition with solid floors. Likely around $250 to $500 once you remove it.
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1824625
05/11/15 11:25 PM
05/11/15 11:25 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Thanks guys.... Got a lead on a 77 cab which is exactly the year I have but good to know about the 91-93 cab......
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1824759
05/12/15 03:02 AM
05/12/15 03:02 AM
Canada
demon Offline
demon  Offline
Canada
Some differences that nobody has mentioned yet. The heater opening in the firewall changed in 1981. So 73-80 cabs use the early heater and 81-93 cabs have a different opening. Plus the square hole for the main wiring harness changed a couple times.
The wiper motor also moved over a bit in the 80's. later truck got a hydraulic clutch so there is holes for that to consider for your earlier truck.
The late cabs have an integral floor hump where the earlier cabs have a removable hump on 4 speed and 4x4 cabs. There are small and large humps too.
The 90-93 cabs are made of lighter metal and dent easier. The rockers got sealed up in those years to prevent dust from entering, but it resulted in rusted out rockers which wasn't really an issue on the 73-82 trucks, especially the 81-82 models which Chrysler went galvanized crazy on for a couple years.
The best cab for your truck would be a 73-80 with the appropriate floor hump
Re: 1977 Club Cab - Other Years.....??..... [Re: demon] #1825306
05/12/15 11:29 PM
05/12/15 11:29 PM
MN
58pwrwgn Online content
58pwrwgn  Online Content
MN
http://minneapolis.craigslist.org/csw/pts/5017084659.html.
There is a supposedly rust free 77 club cab in the minneapolis craiglists autoparts section.
Re: 1977 Club Cab - Other Years.....??..... [Re: 58pwrwgn] #1825310
05/12/15 11:30 PM
05/12/15 11:30 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Thanks!! That is the one I am working on now.
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1830306
05/19/15 08:45 PM
05/19/15 08:45 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I don't recall the clubcab stopping production. Theres a 90 for sale not far from me.
The Firewall had changes for the HVAC and wiring bulkhead
Re: 1977 Club Cab - Other Years.....??..... [Re: 76dodgeboy] #1830869
05/20/15 03:47 PM
05/20/15 03:47 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
They did for a few years but I think Wikipedia and the responses above about are wrong about 91 being the restart. It was 1990.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1868010
07/11/15 12:06 AM
07/11/15 12:06 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
I have absolute proof that if you are looking to buy a solid sheet metal vehicle....."DO NOT" under estimate places like MN where you would normally see cars & trucks that did not win the battle of Winter road chemicals....
I do not have any pictures in this computer right now to post to show everyone but when I saw this truck cab for the first time 2 days ago....I was completely blown away as to how wickedly "SOLID" this thing is for a near 40 year old vehicle.
The one I bought is the one in the MN, MN Craigslist auto parts section. All I really wanted from it was the club cab shell but it came with the rolling chassis and even the frame is nice...!! (no bed, doors or front clip) but I got a steal of a deal for what I did get.....!!!
This cab is so nice.....if a person did not know that it came from MN, you would swear that it came from NV, AZ, NM, CA, WA or any other dry climate state. I cannot wait to take the pressure washer to the bottom of it and clean the metal........
Re: 1977 Club Cab - Other Years.....??..... [Re: E-Ticket] #1868061
07/11/15 01:46 AM
07/11/15 01:46 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There us a real nice club cab here at Carlisle this weekend. The guy has all kinds of cabs and I going to talk to him tomorrow to see if he has the doors off the regular cab he has on the top of his trailer as it matches the paint on my 93! luck
JB Rhinehart, Realist
A-Body's RULE!
